Fur Motion Blur
Forums: Fur Motion Blur
Houdini Integrated Plugin
Fur Motion Blur
Postby derekhanz » Fri Aug 17, 2018 10:10 am
derekhanz Fri Aug 17, 2018 10:10 am
I'm using H16.5 and Octane 3.08.1.0_Houdini_16.5.439_Win64.
Can't get Motion Blur working at all.
Checked it on in the ROP settings.
Motion Blur works fine for every other object but not fur.
Do I need to feed velocity attribute into the hairgen node?
Any thoughts?
Thank you.
derekhanz
Re: Fur Motion Blur
Postby juanjgon » Mon Aug 20, 2018 8:33 am
juanjgon Mon Aug 20, 2018 8:33 am
Have you tried to render the motion blur computing the velocity attribute with the Trail SOP? Perhaps the problem is that the hair object doesn't have a constant topology among the frames, making the computation of the motion blur from the mesh deformations impossible.
In any case, if you want to share a sample scene with this issue, I can take a look at it.
Computer Graphics Software Developer
Octane plugin development and support: LightWave and Houdini
juanjgon
Re: Fur Motion Blur
Postby derekhanz » Tue Aug 21, 2018 11:28 am
derekhanz Tue Aug 21, 2018 11:28 am
I'm trying to upload the working .hip file but it won't let me.
'The extension hip is not allowed.'
derekhanz
Re: Fur Motion Blur
Postby juanjgon » Tue Aug 21, 2018 3:53 pm
juanjgon Tue Aug 21, 2018 3:53 pm
derekhanz wrote:I'm trying to upload the working .hip file but it won't let me.
You could .zip or .rar the file, or send it to me directly to [email protected]
juanjgon
Re: Fur Motion Blur
Postby juanjgon » Fri Aug 24, 2018 10:11 am
juanjgon Fri Aug 24, 2018 10:11 am
Like I had supposed, the problem was the lack of the velocity vectors (the "v" point attribute) in the final curves OBJ node. As you can see in the attached image, you must add the "v" point attribute to the output attributes in the hair generate OBJ node.
Hope it helps,
juanjgon
Return to Houdini
Who is online
Sat Jan 18, 2020 9:45 am [ UTC ]
