Help me with the noise in the image
sergiomatheo
When I go to render a scene and the active pathtracing the picture is full of noise, and these noises do not always gone as I solve this? has increased the higher light does not work, continued noise in the image, what I do to eliminate these noises of the image?
Refracty
Strong noise could exists be because of:
1. Bright spots in HDRI - Solution: play with gamma or blur the HDRI
2. Extremely powerful lightsources - Solution: lower power
3. tiny lightsources - Solution: try to make them bigger if possible
4. Short rendertime - Solution: Cook the render longer
Daniel
There's also a noise removal feature that automatically removes usually around 99% of noise (from my experience), but should only be applied once a render has cooked for a while. Otherwise the image looks blurry.
Core i7 950 @3.07GHz | GTX 460 2GB | 12GB RAM | Window 7 x64
pegot
I'm new to Octane - where is the noise removal feature?
Thanks!
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
radiance
You should render your final images with the 'PMC' kernel, not the 'pathtracing' kernel,
and give it enough time. Also, purchasing a high-end gaming GPU like a GTX560-70-80 will make octane run as it's meant to run.
An alternative is using the 'directlighting' kernel with the indirect lighting changed from 'ambient occlusion' to 'diffuse'.
This will give a slightly less realistic image, but much faster render times with less noise.
Radiance
