- - [NEW]: Camera update only mode: starts Octane without exporting, only updating camera. OBJ/MTL files must exist and 'Export Camera from Scene' must be checked on.
- [FIXED]: some issues (may be not all of them) with linked objects/groups
- [FIXED]: got rid of stupid complains from Blender about descriptions ending with a dot
- [REMOVED]: 'Fly' mode (almost obsolete assuming render time is higher than export time. I can put it back on popular demand, but interface will look ugly)
- [REMOVED]: 'Bucket' mode, still not implemented awaiting for new communication format with Octane
- [TESTED]: with blender 2.60.41346, but should work starting 2.58.31xxx and higher
- [WARNING]: ocs writes still there but not updated - will reverse your materials to earlier Octane version (still compatible but less parameters). KNOW WHAT YOU'RE DOING if using it.
[Unsupported] Blender plugin v1.11
Please find attached updated plugin.
- Attachments
- octanerender.v1.11.zip
- (63.44 KiB) Downloaded 612 times
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
Hi Lionel
Thank you so much for your continued hard work with this. As a new arrival to Octane I could not get Blender & Octane to work together! I Felt (with little research) that the Blender support was non existant... How wrong can one guy be! Guess it pays to actually do your research FULLY first eh! Seems I jumped the gun when things didnt go my way straight off the batt! A learning curve for me. Your work is important to us all (Blender comunity wise) and I hope you continue to support Blender.
With much gratitude
With much gratitude
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
did you select the Octane render engine from the dropdown at the top?orion_uk wrote: If I press the render animation button the Blender render engine starts to render my animation, not Octane!
cgmo.net
cgmo.net
- Biennal Crab
yoyoz thanks for your work, I will try the new plugin soon as I can
Intel Core I7_920 | Win7 64 | 9GB ram | GTX590 x Octane | Blender 2.76 | SketchUp 8 PRO | GIMP | RawTherapee
matej wrote:did you select the Octane render engine from the dropdown at the top?orion_uk wrote: If I press the render animation button the Blender render engine starts to render my animation, not Octane!
@matej....Lol, I deleted that part of the post as I sorted it!
TBH, I dont know how! I just created a new scene in Blender and re-imported all my mesh/scene data!
Thanks anyway
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
Here's the option you need:
- MadMinstrel
Thanks for your great work, Yoyoz!
Is there something I'm missing or is the blackbody emitter efficiency setting not accessible anywhere in blender?
Win 7 x64 | Geforce GTX295 | Quad 2.4GHz | 4GB
Why would you even need that setting accessible in the exporter? Tweaking lights power is applicable to the rendering program (where you have a visual on your changes) not to the modeling program. The exporter should not try to re-create every aspect / parameter of Octane rendering pipeline, because it will become needlessly bloated. I never touch any material settings in the exporter, because shading is the interactive part of Octane, not Blender.MadMinstrel wrote: is the blackbody emitter efficiency setting not accessible anywhere in blender?
Blender (tasks: modeling, applying tex. to UV) -> exporter -> Octane (tasks: shading, lighting, rendering)
cgmo.net
cgmo.net
- MadMinstrel
I'd agree for materials but I do my lighting while I'm modelling (before I even start to UV) and I like to test my scene often. Not having that setting forces me to set it in octane for every light in the scene each time I test. It's just another float value. Since there are plenty of other, less useful settings (ray epsilon in kernel settings? anybody ever changes that?), I don't see why this pretty important one should be left out.
