tilt-shift lens
Chris
We need a tilt-shift lens function in Octane, its very important for archviz.
Cheers
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
Proupin
True
radiance
do you mean tilting the camera around it's axis, like turning your head onto your shoulder ?
or do you mean the perspective is only horizontal, eg the vertical elements/walls are all parallel ?
Radiance
Sam
parallel vertical element
Like in archviz photography :D
[gk]
you can do that with nuking your scene in scale and decrease DOF...
Ive seen alot of renders here and elsewhere where people has a bad understanding of DOF which results in this effect - as in unintended.
Amiga 1000 with 2mb memory card
Sam
gk, this is bad use of a tilt shift, just like bad HDRI photography, over-done
What we want in Octane is not that kind of result
Its correcting verticals, not adding extreme DOF :lol:
[gk]
show
Sam
:lol:
The goal is to have a normal lens (50mm for example) with almost no barrel distorsion
[gk]
ah barrel distortion calibration, ok.
I use this on footage that needs to be 3d tracked from time to time.
Should have called topic something along with "barrel distortion fix" or something, got my mind on a tangent and radiance it seems as well :)
James
I knew Tilt-Shift as what gk was talking about, it is pretty awesome to use on a real camera, and you can use it to make strange perspective shots, but it is most awesome for making large scale things look tiny...
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
