OctaneRender for Blender Addon 2026.6 - 31.13 (for Blender 5.2.2) [STABLE]
azen
We are excited to bring you the latest Stable Release, for the OctaneRender for Blender Addon!
This Addon Release is only compatible with Blender 5.2.2 - previous Blender 5.x and 4.x releases are not supported.
This version works on the "vanilla" Blender 5.2.2 release, that you can download and install from the Blender Foundation website ( https://www.blender.org/ ).
1. OctaneRender™ Server
2. OctaneRender for Blender Addon
How to Install
  • Download the addon and the server files
  • Run the Octane Addon Server installer (or, if you downloaded the ZIP file, extract the Octane Addon Server zip file to any location on your hard drive)
  • Launch the Octane Addon Server
  • Launch Blender and from Preferences -> Add-ons, click on the small arrow at the top right and choose "Install from Disk..."
  • Select the downloaded .zip archive of the Octane for Blender addon
  • Select File > New > OctaneRender Startup (Direct Lighting), or File > New > OctaneRender Startup (Path Tracing)
  • Quit, and then relaunch Blender
CHANGES SINCE LAST RELEASE
  • Update to Octane 2026.6
  • Optmized animation rendering
FIXES SINCE LAST RELEASE
  • Fixed Launch Server for a Server folder typed or pasted without a trailing separator
  • Fixed Launch Server waiting out its timeout when the Server stops right after starting
  • Fixed the Linux Server spinning, quitting or freezing when started without a terminal or in the background
  • Fixed crash issue on Linux Server, related to certain animation rendering cases
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2026.6 here:
viewtopic.php?t=85881
Octane Blender Addon
All Platforms
Blender Addon - All Platforms - Studio/Prime Edition
OctaneServer (Installers)
Studio+ Edition - for Studio+ Subscription Users
Octane Server - Windows
OctaneServer - Linux
Prime Edition - for Prime (Free-Tier) Edition Users
Octane Server - MacOS (Metal)
OctaneServer (ZIP Files)
Usage
  • Start with a default scene (File > New > OctaneRender Startup (Direct Lighting) or File > New > OctaneRender Startup (Path Tracing))
  • Convert a scene from the non-addon version: "File > Export > OctaneBlender Addon". Please report any problem you may find when converting your scenes!
Bug Reports
For faster troubleshooting, please provide as much information as possible. Please include:
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots)
  • If possible, Blend files for direct testing would also be appreciated
If you are unable to share a copy of the affected scene, please try running Blender in debug mode and send us the logs instead.
  • Open the directory of the Blender executable file.
  • Double-click the blender_debug_log.cmd file to open it.
  • This will launch Blender in debug mode and automatically start capturing logs.
  • Reproduce the issue you are experiencing in Blender.
  • Once you have finished reproducing the issue, close Blender.
  • Blender will open a folder containing error log files.
  • You can then send us the blender_debug_log.txt file to help us diagnose the issue.
You can get more information about the debug command at https://docs.blender.org/manual/en/latest/troubleshooting/crash.html.
