Octane 2026.6 for Cinema4D - 2.0.3
ChrisHekman
Hi all,
This build provides Cinema4D 2027 support
This build contains OctaneRender 2026.6
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.6 - 2.0.3 Plugin Changes
  • Cinema 4D 2027 support
  • C4D 2027 Scatter generator. It renders just like a Cloner in Octane, including multi-instance rendering, motion blur and the MoGraph id attributes.
  • C4D 2027 Liquid FX. Sphere particles from the Spray, Foam and Bubbles particle groups now render with their material.
  • Instance Color texture on simulation Particle Groups  (Liquid FX and C4D Particles).
    It can now color particles by age, radius, speed, distance travelled, rotation, spin, mass or density through a gradient.
  • Fixed issue where Redshift cameras would be ignored
  • C4D-487 VDB sequences asset collection now picks up the right files when the sequence’s start frame differs from the first file’s number. The last file and the base file are no longer missed.
  • C4D-472 Chinese (zh-CN) UI the Live Viewer and render info show real render times again instead of C4D’s placeholder text.
  • Fixed issue where particle meshes in a particle node graph would not properly connect to the material
Downloads:
WINDOWS STUDIO+ 2026.6 - 2.0.3 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.6 - 2.0.3 (R21-R2026)
Archive
WINDOWS DEMO 2026.6 - 2.0.3 (R21-R2026)
Installer
Archive
2026.6 - Nodes
OctaneRender Studio+ 2026.6 Node for Windows (installer)
OctaneRender Studio+ 2026.6 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.6 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
