Octane 2027.1 Alpha 3 for Cinema4D - 2.0.2 - Alpha Release
ChrisHekman
Hi all,
This is a small fix build for people that have issues starting the C4D when the plugin is active.
Next build will have MacOS27 support. If you want to use MacOS27 you can use the 2026.6 build of 2.0.2
This build contains OctaneRender 2027.1 Alpha 3
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
Known issues:
  • MacOS support will come later
2027.1 Alpha 3 - 2.0.2 Plugin Changes
  • Fixed issue C4D would freeze when user had an issue with their Octane License
Downloads:
WINDOWS STUDIO+ 2027.1 Alpha 3 - 2.0.2 (R21-R2026)
Installer
Archive
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
