Octane Sketchup with 2027.1.Alpha2 -1.0 [Test]
BK
Otoy® is proud to announce the availability of a new version of OctaneRender™ for SketchUp® 2024, 2025 & 2026 C API integration.
The world's fastest and most feature-rich unbiased render engine that integrates complete SketchUp and native features.
For example, Shadows, Layers, Native material picker, Automatic material converter, Data sync, etc.
Version Requirements
This release will work with SketchUp® Versions 2024, 2025 & 2026 64-bit on MS Windows and macOS.
Performance comparison between Old and the new C API
MaterialX Import workflow:
OctaneRender Standalone 2027.1 Alpha 2 feature improvements and to download OctaneRender nodes for Network Rendering
viewtopic.php?t=85747
Change log since the last release
  • - Updated to version 2027.1.Alpha2
  • - Bug fixes
Please note: If there is any missing texture in the render, then make sure the material exists/listed under In Model.
Exploding the groups would fix this issue.
-The preview does not match the SketchUp viewport because each MaterialX shader can have its own unique UV mapping setup, which varies from one shader to another.
It’s therefore not possible to use a universal converter to translate MaterialX UV mapping into SketchUp’s native viewport mapping.
- No LiveDB for macOS build since we are using the prime tier.
We are finally switching to C API with performance boost, and improvements etc. We look forward to your feedback
Downloads
Important:
[*] The minimum NVIDIA driver version required is 572.
[*] Supported versions of macOS currently are macOS15 and macOS26.
OctaneRender for SketchUp Prime macOS
[For Trimble Sketch macOS](Link)
OctaneRender for SketchUp Studio+
[For Trimble Sketch Windows](Link)
Happy GPU Rendering!!
Sincerely yours
OTOY
Kind Regards
bk3d
