Octane Server closes every time after rendering a few frames
miohn
and then - of course - I get the error message "cannot connect to server"
Is this a known problem?
Happens with 31.5 as well with 31.6
reagds
Mike
miohn
has this maybe to do with Orbx-Objects?
When rendering 500 Frames its a little bit annoying to
restart server, set new start frame and restart render animation every 5 or 6 frames .....
miohn
it seams that this only happens with orbx objects.
When importing fbx or other its rendering fine!
regardsMIke
linograndiotoy
Hi Mike!
Could you please share the scene with us?
Thanks!
miohn
Hi Lino,
sorry I can't because its an aktuel Project with data from the client.
I exported the object from C4D/Octane as ORBX and imported it to Blender 5.1 and Octane 31.6
like you told me.
A few frames it renders fine and then it stops (Server first or Blender first I cannot say)
Maybe you can reproduce it with an any other object and same workflow.
best regards
Mike
bth. I exported only the object without any lights and camera and did
the lighting and animation in Blender
linograndiotoy
I've tried here, no luck reproducing the issue.
Return to “Blender”
