OctaneRender 2026.2.0.1 for Houdini Production (2026.2.0.1)
bruce.chai
This is a production release of the OctaneRender™ 2026.2.0.1 for Houdini™ plugin compiled with the Octane 2026.2 core. This 2026.2.0.1 release is available for the latest Houdini production builds on Windows x64, Linux.
Houdini production builds supported by this release: 20.0.896, 20.5.684, 21.0.559, 21.0.596 and 21.0.631.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
New features
To learn more about the new features and improvements of OctaneRender 2026.2, please check out the 2026.2 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2026.2.0.1 Studio+ license
Windows Houdini 20.0.896
Windows Houdini 20.5.684
Windows Houdini 21.0.559
Windows Houdini 21.0.596
Windows Houdini 21.0.631
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.684 (gcc11.2)
Linux Houdini 21.0.559 (gcc11.2)
Linux Houdini 21.0.596 (gcc11.2)
Linux Houdini 21.0.631 (gcc11.2)
Release 2026.2.0.1 macOS Prime license
MacOS Houdini 20.0.896
MacOS Houdini 20.5.684
MacOS Houdini 21.0.559
MacOS Houdini 21.0.596
MacOS Houdini 21.0.631
Release 2026.2.0.1 Demo version
Release Notes
RELEASE 2026.2.0.1
PLUGIN FEATURES AND FIXES:
  • Much improved update behaviour. This should resolve a lot of bad performance issues on complex scenes and resolve freezing of the IPR.
  • These things now also update the IPR: COPs edits, Object merge dependencies, material transforms linked to control nulls, focus expressions etc
  • New option in octane options under IPR tab: disable IPR async (enabled by default). Generally the async IPR "should" improve viewport usability in heavy scenes as the IPR releases the Houdini UI much faster (instead of being frozen until the actual rendering starts). But we added a toggle here for debugging purposes or scenarios where async creates other issues.
  • Fixed info pass kernel info settings not propely working.
  • Improved light placer performance in heavy scenes
  • Added an octane options button to render setup
  • Fixed a bug where the octane toolbar would create an outdated version of the universal light HDA
  • Improved IPR reload/reopening performance with large texture files (they are now cached/kept around)
  • op: context support for mtlx image nodes
  • op: context now uses hdr 32-bit colors - so values beyond 1 are no longer clamped and reduces stepping on things like displacement etc
  • A sop octane quickmaterial now no longer forces the geometry of the current node to be reloaded resulting in decreased lag when modifying parameters.
  • Octane RenderSetup and RenderTarget now by default include a linked camera imager in the outputAOV example setup - for quick and easy "ipr look aov - including imager settings postprocessing with tonemapping applied"
NOTE: Octane 2026.2 core has some issues around the texture displacement (specifically high quality mode) - this includes objects disappearing as well as other errors. These are not resolved in this build, but should be in the next 2026.x core release (edited)
OctaneRender for Houdini tutorial
Still updating
Note
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "<path_to_plugin_directory>"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "HOUDINI_MENU_PATH": {
                "value": "$OCTVERSION/config/Menus"
            "HOUDINI_SCRIPT_PATH": {
                "value": "$OCTVERSION/scripts"
            "PATH": {
                "value": "$OCTVERSION/bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION/dso/usd_plugins"
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package.
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
lavrenovlad
I noticed that Ctrl + Z isn't recognized by IPR as some action that needs an update, so if I work with a material and do ctrl + z to plug/unplug a node IPR won't refresh
Zunder
Hi! Very nice release, so far so good!
I would like to suggest kinda of a "fix", when "Valid Frame Range" on Octane Render Setup node is set to "Render Current Frame" "Start/End/Inc" should be greyed out, this way it's more clear that you've set this option. And it's also default throughout houdini
Thanks!
k3xx
This is the best version of the plugin ever so far. I was waiting for this level of stability and seamless experience since 4.0 (8 years)!
I can just work without crashes or slowdowns while the IPR is running nicely in Houdini, I'm so happy! :D
k3xx
I think the spotlight geometry should be like this otherwise the tube moves when you adjust the height.
dom_otoy
k3xx wrote: Thu Mar 26, 2026 1:14 pm houdinifx_l25KserNhl.png
This is a good suggestion - will add this!
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
dom_otoy
Zunder wrote: Wed Mar 25, 2026 8:32 am Hi! Very nice release, so far so good!
Thanks!
Added a ticket for this.
Will add it to the RenderSetup right away, the ROP might take a little while (as currently the parameters are hardcoded)
Happy Rendering!
dom_otoy
lavrenovlad wrote: Mon Mar 23, 2026 11:52 am I noticed that Ctrl + Z isn't recognized by IPR as some action that needs an update, so if I work with a material and do ctrl + z to plug/unplug a node IPR won't refresh
Opened a ticket!
Happy Rendering!
lamloops
Hey gang
Looks like the link to see the new 2026.2 features not work for my username. It says I'm not allowed to see / don't have permission. Any chance of a fix?
lamloops
This link works fine - viewtopic.php?t=85487
but not this one
viewtopic.php?t=85488
