Baking Post Processing Effects into individual denoise light passes.
MISTER_SYD
Hi all
when i render out of octane i usually render all the lights separately and then bring them all back together in AE so i can have individual control of each light.
On this project we have used Post Processing effects (Image processing / Lens Effects)
but if i render out a separate Post Process pass it doesn't line up with my individual light passes, I'm guessing this is mainly due to the lens effects.
is there a way to bake the post processing effects into the individual light passes.
Thanks.
MISTER_SYD
ok i figured it out
if i use the render node editor and then apply the "Add chromatic aberration" to all the light passes and the post effects pass then it works. plus i removed the chromatic aberration intensity off the post effects.
