OctaneRender 2026.2 for Houdini Production (2026.2.0.0)
bruce.chai
This is a production release of the OctaneRender™ 2026.2.0.0 for Houdini™ plugin compiled with the Octane 2026.2 core. This 2026.2.0.0 release is available for the latest Houdini production builds on Windows x64, Linux.
Houdini production builds supported by this release: 20.0.896, 20.5.684, 21.0.559, 21.0.596 and 21.0.631.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
New features
To learn more about the new features and improvements of OctaneRender 2026.2, please check out the 2026.2 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2026.2.0.0 Studio+ license
Windows Houdini 20.0.896
Windows Houdini 20.5.684
Windows Houdini 21.0.559
Windows Houdini 21.0.596
Windows Houdini 21.0.631
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.684 (gcc11.2)
Linux Houdini 21.0.559 (gcc11.2)
Linux Houdini 21.0.596 (gcc11.2)
Linux Houdini 21.0.631 (gcc11.2)
Release 2026.2.0.0 macOS Prime license
MacOS Houdini 20.0.896
MacOS Houdini 20.5.684
MacOS Houdini 21.0.559
MacOS Houdini 21.0.596
MacOS Houdini 21.0.631
Release 2026.2.0.0 Demo version
Release Notes
RELEASE 2026.2.0.0
PLUGIN FEATURES AND FIXES:
Changes:
Probably the biggest difference is that the IPR Render update is mostly async now which should make working with big scenes less painful while the IPR is running.
This means that Octane will release the Houdini UI faster after the scene changes are updated to Octane node graphs, which means less freezing time of the Houdini UI. This doesn't necessarily mean that the IPR will load faster, but it means you can keep working while the image is being rendered out by Octane. This should lead to less interruptions of the creative flow.
  • Fixed instanced light object transformation
  • IPR "Fill window" mode fixes
    - Skip scale if zoom level is 100%
    - Fixed resolution change in fill window mode and zoom level is not 100%
    - Fixed crash due to scroll area and image widget have same width or height
    - Made sure fit is same as 100% for fill window mode
    - Update image widget size when camera resolution changes
  • Faster IPR image drawing
  • Avoid checking referrencing node for OctaneRenderSetup for better performance
  • Don't collapse standard surface when Octane material is created
  • Avoid creating duplicated same instanced object
  • Change "Priority" checkbox to "Use priority"
  • Added NT_MAT_OPEN_PBR_SURFACE node
  • Fixed instanced light layer settings
  • Support H21 native GS (generated by bakegsplat sop node)
  • Automatically guess which GS geo mode according to availabe point attribute set (GSOPS compatibily mode parameter is now depreciated)
  • Imager, post processing, OutputAOVs (when Lock render AOVs settins is enabled) parameter changes in most cases no longer restart the render.
  • Fixed several IPR issues related to Fill Window mode
  • Changed default analytic light spread from 180 degree to 60 and cutoff hardness from 1 to 0.5 to match Octane Standalone defaults
  • Improved Octane Render Settings file path python callback script to better accommodate expressions (use ` quotes for expressions)
  • Fixed crash when using GSOPS Evaluate Spherical Harmonics node
  • Switched back to faster IPR canvas scale mode, but found different workaround to fix the alpha channel bug.
  • When creating an Octane Material Builder the Standard Surface node inside is no longer collapsed by default.
  • Fixed crash when using too many individual obj level instance nodes referencing the same object
  • Renamed GPU setting "Priority" checkbox to "Use priority" to avoid confusion
  • Other small performance improvements
  • New barndoor option in Universal Light - Modify options
  • Added a new message to the IPR bottom right corner that shows how many octane changes are pending -> since the IPR is now async this lets users know how up-to-date the IPR is/how many changes are in the queue.
  • Added neural radiance cache parameter to photon tracing kernel
  • Added new info render aov: Metalness AOV Updated info kernel's Type parameter for the new option: Metalness Added universal camera's compatibility version parameter
  • New color attribute parameter in the object attributes panel -> this is used for mtlx geometry color node -> set to Cd by default
  • The attribute panel now by default has Cd in the point attribute section
  • Fixed gaussian splat focus picking not working
  • HScript command to export a specific material to orbx file: `Octane_exportMaterial <Octane Material Path> <exported orbx file path (ends with .orbx/.ocs)>`
OctaneRender for Houdini tutorial
Still updating
Note
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "<path_to_plugin_directory>"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "HOUDINI_MENU_PATH": {
                "value": "$OCTVERSION/config/Menus"
            "HOUDINI_SCRIPT_PATH": {
                "value": "$OCTVERSION/scripts"
            "PATH": {
                "value": "$OCTVERSION/bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION/dso/usd_plugins"
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package.
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
lavrenovlad
Thanks for the awesome release and good work Bruce!
caseyhupke
on macOS Im currently getting a crash on the creation of any geo at /obj level.
08:25:21 ERROR: [OBJ parm] ----------      Cannot open parm ds file Octane_2026.2.0.0_Houdini_21.0.596_Prime_macos/scripts/DSFile/OctaneHoudini_GeoParms.ds
2705: Fatal error: Segmentation fault (sent by pid 0)
macOS Tahoe 26.3
Houdini 21.0.596
no other packages installed, just vanilla Houdini and Octane.Verified that DSFile is present on disk, and paths all work as expected.
bruce.chai
caseyhupke wrote: Wed Feb 25, 2026 4:29 pm on macOS Im currently getting a crash on the creation of any geo at /obj level.
macOS Tahoe 26.3
Houdini 21.0.596
what is the "OCTVERSION" setting in your Octane.json? It should be a full path to the plugin.
It looks like your "OCTVERSION" is just "Octane_2026.2.0.0_Houdini_21.0.596_Prime_macos" rather than the full path.
I would suggest using the createPackageFileForOctane.sh script in the plugin directory to update the Octane.json which will automatically set "OCTVERSION" with the correct path.
caseyhupke
its the same path that I've been using for my octane package for years now, including the previous version of 2026.
its a variable thats set to a _PLUGIN folder in my Houdini prefs folder.
bruce.chai
caseyhupke wrote: Wed Feb 25, 2026 9:01 pm its the same path that I've been using for my octane package for years now, including the previous version of 2026.
I don't really know what "a _PLUGIN folder" means. is _PLUGIN is a environment variable? Can you backup your current Octane.json and test if the Octane.json file crated by createPackageFileForOctane.sh script works for you?
stevepickup
Just for anyone on windows having a problem with installing using the new packages meathod when your Documents folder is not in the default location... in my case i have OneDrive installed to automatically back everything up.
Stick the downloaded Octane folder where you would normally put it.
Open notepad as an admin, and find and open the 'createPackageFileForOctane' (the one in the Octane folder) in notepad.
Look for:
:: Get the path to the current user's Documents folder
Change:
set "DocumentsPath=%USERPROFILE%\Documents"
To your path:
set "DocumentsPath=%USERPROFILE%\OneDrive\General Backups\Documents"
Save and then run the 'createPackageFileForOctane' from the Octane folder to create the correct JSON file for final instal.
Open Houdini and should now work
dom_otoy
stevepickup wrote: Sun Mar 08, 2026 11:09 am Just for anyone on windows having a problem with installing using the new packages meathod when your Documents folder is not in the default location... in my case i have OneDrive installed to automatically back everything up.
Look for:
Change:
To your path:
Btw here's a video going over the different install methods :)
https://www.youtube.com/watch?v=f0AX-YBRQAw
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
