Can't render scene
shtl_1
Hello.
My scene wont render and I can't find why.
It rendered correct last night, I modified few stuff here and there and now it won't render at all anymore.
Restarted computer, doesn't help.
I'm OSX 26.2 Apple M1 Ultra 48 core 128 Vram
OctaneRender_Prime_2026.1_for_Cinema4D_v1.8
Here a resumed copy of log :
Started logging on 08.02.26 16:45:54
Octane X Prime 2026.1 (15000009)
initOCIOconfig cfgFile: OCIO_ENV:
disableAllDevices
VRAM used/free/max:0Kb/128Gb/128Gb Out-of-core used:0Kb RAM used:44.212Gb total:128Gb OpenGL free/total:0/0
Convert Octane Daylight Environment medium thickness from:46975.888 to:4697588.817
Convert:[RandomWalkMedium] singleSct=2.595
Convert:[RandomWalkMedium] singleSct=0.045
Convert:[RandomWalkMedium] singleSct=0.062
Convert:[Scattering Medium] singleSct=0.01
Convert:[Scattering Medium] singleSct=1209.19
Transfer LV settings to Octane VPost...
Tried to access pin via an invalid ID P_INDEX4 (411)
Tried to access null node pin
Tried to access pin via an invalid ID P_INDEX_MAP (440)
--------------------------- EXPORT LOG ---------------------------
Tried to access pin via an invalid ID P_NEURAL_RADIANCE_CACHE (2640)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x31176cb70)
Mesh creation time = 2016.906 ms.
Can't read bool from static pin 'upsamplerType' (P_UPSAMPLER_TYPE, type PT_ENUM) of node 'Imager' (NT_IMAGER_CAMERA, 0xbdca23200)
Can't read bool from static pin 'upsampleSourcePercentage' (P_UPSAMPLE_SOURCE_PERCENTAGE, type PT_ENUM) of node 'Imager' (NT_IMAGER_CAMERA, 0xbdca23200)
Api update time: 37.771 ms.
Any help would have been usefull. :(
EDIT:
Here is crash report:
bugreport_20260208_164554.zip
(9.07 KiB) Downloaded 50 times
shtl_1
I redid the scene with last working version… and copy past all new elements 1 by one.
It still crashes time to time but it renders. Maybe A gradient node on Hair Geometry generated mesh ?
Blah !
Good to hear you have partially solved.
If you can share the scene with me via Private Message, I can try to have a look to it.
ciao,
Beppe
shtl_1
Ciao Beppe !
I still have many 440 441 errors with any scene in OctaneX, wonder what it is ?
Anyhow I'll share the scene, thank you very much.
Ok, please write to help at otoy dot com asking for Beppe, in this way I can investigate more deeply.
ciao,
Beppe
