Octane UI: collapse / expand internal node groups (small Blender add-on)
linograndiotoy
Hi everyone,
I’m sharing a small Blender add-on that lets you collapse / expand the internal UI groups of Octane nodes (Transmission, Base Layer, Specular, etc.) with a single click.
octane_ui_collapse.zip
(1.96 KiB) Downloaded 96 times
This does not hide the node itself.
It operates on the UI foldouts of Octane nodes, using the same mechanism Blender uses when you manually collapse a group (show_group_sockets).
Collapse.mp4
(235.18 KiB) Downloaded 70 times
Features
Works on any Octane node that uses grouped UI sockets
Collapse, expand, or smart toggle (if anything is open → collapse all)
Available from:
  • Right-click menu in the Node Editor
  • N-panel > Octane > UI Collapse
Installation
The add-on is provided as a single .py file (attached to this post)
Install via Edit > Preferences > Add-ons > Install…
Why
On complex materials, especially layered or Universal setups, collapsing UI groups helps keep node graphs cleaner and easier to navigate.
Notes
  • This is a UI helper only; it does not modify any shading parameters
  • Not limited to the Universal Material — it works across Octane nodes that expose grouped UI sockets
Feedback and suggestions are welcome.
Return to “Blender”
