Realistic Camera
remKa
Hello,
Realistic camera doesn't update when I apply a rotation to it, no matter if I relaunch the viewport or click on the update scene button (version 2026.04) :
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
paride4331
Hi remKa,
I can’t reproduce the issue on my end. Are you sure Movable Proxy is enabled?
Regards
Paride
remKa
On max 2026.3.2 I can't set "movable proxy" for a realistic camera, I have to put a Octane Geometry Properties above the camera to make the rotation working
paride4331
Hi remka,
I meant the movable proxy on the objects. Anyway, it looks like everything is working, did I get something wrong?
Regards
Paride
test.mp4
(6.04 MiB) Downloaded 32 times
remKa
Hello Paride, when I move an object there is no problem, it's when I rotate the camera that nothing happens
paride4331
Hi remKa,
Have you tried disabling Target Mode?
Regards
Paride
remKa
Yes it doesn't work (and I need the target ^^)
paride4331
Hi remKa,
Could you share a video of the issue?
Regards
Paride
remKa
Sure, here it is.
It is the "roll camera" tool that is not responsive, no issue with the "dolly".
And when I attach the camera to a dummy, I can rotate the camera in the X axis but not in the Y axis (like the roll tool).
WhatsApp Video 2026-02-18 at 11.09.10.mp4
(4.62 MiB) Downloaded 30 times
paride4331
Hi remKa,
got it, thanks.
Paride
Return to “Autodesk 3Ds Max”
