OctaneBlender Addon 2026.1 - 31.2 Beta Release (for Blender 5.0) [OBSOLETE]
azen
We are excited to bring you the latest beta version of the OctaneBlender addon!
IMPORTANT: This Addon Release is only compatible with Blender 5.0 - previous Blender 4.x releases will not be supported by this Addon version.
This version works on the "vanilla" Blender you can download and install from the Blender Foundation website ( https://www.blender.org/ ).
This means there's no need for a custom build anymore!
Running the Octane server is still needed.
Here we have the optimized addon version ready to be released on the forum as the Beta.
Generally, this version includes significant changes that dramatically improve performance, and dozens of new features and bug fixes as well.
We will continue developing/updating both the addon and non-addon versions, until the addon version can be declared stable.
Octane Blender Addon
All Platforms
Blender Addon - All Platforms - Studio/Prime Edition
OctaneServer
Studio Edition
Octane Server - Windows - Studio Edition
OctaneServer - Linux - Studio Edition
Prime Edition
Octane Server - Windows - Prime Edition
Octane Server - MacOS (Metal) - Prime Edition
Octane Server - Linux - Prime Edition
How to Install
  • Download the addon and the server files
  • Unzip the Octane Addon Server in any location on your hard drive
  • Launch the Octane Addon Server (OctaneServer.exe)
  • Launch Blender and from Preferences/Addon, install the Octane for Blender addon
  • Select File > New > OctaneRender Startup (Direct Lighting) or File > New > OctaneRender Startup (Path Tracing)
  • Quit Blender
  • Launch Blender again
Now you can use Octane on the most current official Blender version!
Scenes created with the current non-addon version may need to be converted to the addon version.
To do that, with the scene, you need to convert loaded in the non addon version, please use File > Export > OctaneBlender Addon.
This will generate a new scene with the "addon" string added to the file name.
As with all beta builds, we advise to not use this release for production purposes.
We are trying to, but we can't guarantee that scenes saved with this version will be compatible in future releases, so, again, do not use this beta for production work.
Features
Generally, We have migrated most of the features from the non-addon version to this addon version.
  • Integrated Blender 5.0
  • Updated the Output AOV system
  • Updated Octane startup scenes
  • Improved the performance when processing object layers
  • Used parent collection's object layer data for its instances
  • Added a Render AOV search operator
  • Auto-select the first AOV/Compositing nodes if available
Bug Fixes
  • Fixed New - Default - Kernel Node
  • Fixed crash caused by recursive compatibility version setter in Blender 5.0
  • Fixed redundant updates of VDBs rendering
  • Fixed Object Layer options for curves have no effect
  • Fixed the Output AOV group issue
  • Fixed crash when exporting ORBX under viewport rendering
  • Fixed update issue when switching preview render pass
  • Bug fixes
Usage
  • Start with a default scene (File > New > OctaneRender Startup (Direct Lighting) or File > New > OctaneRender Startup (Path Tracing))
  • Convert a scene from the non-addon version: "File > Export > OctaneBlender Addon". Please report any problem you may find when converting your scenes!
As this is a Beta release, you may find issues. Please report any bugs and/or missing features, possibly providing the scene and steps to reproduce the problem.
Some converted scenes may not work properly - please report any of them.
Bugs & Issues
This is a beta version, so there may be issues and bugs. Please report any bugs and/or missing features, possibly providing the scene and steps to reproduce the problem.
If you are unable to share the scenes, please try running Blender in debug mode and send us the logs.
How to run Blender in Debug mode
  • Open the directory of the Blender executable file.
  • Double-click the blender_debug_log.cmd file to open it.
  • This will launch Blender in debug mode and automatically start capturing logs.
  • Reproduce the issue you are experiencing in Blender.
  • Once you have finished reproducing the issue, close Blender.
  • Blender will open a folder containing error log files.
  • You can then send us the blender_debug_log.txt file to help us diagnose the issue.
You can get more information about the debug command at https://docs.blender.org/manual/en/latest/troubleshooting/crash.html.
linograndiotoy
This addon update fixes a problem happening when switching to an Octane Preset from some of Blender's own presets:
octane_blender_addon-31.2-beta(6).zip
(12.99 MiB) Downloaded 208 times
linograndiotoy
This new updated version provides improved Octane preset files.
octane_blender_addon-31.2-beta.zip
(12.99 MiB) Downloaded 187 times
linograndiotoy
We have a new update fixing the reported issues so far:
Changelog since the last iteration:
-Supported relative path in GUI for octane output path
-Fixed repeat-added new sockets when checking backward compatibility
-Fixed the default value issue of the typed socket
-Fixed OSL socket value storage for Blender 5.0 (remove IDProperty usage)
-Fixed a compatibility update failure for OctaneOutputAOVsOutputAOVGroup nodes
octane_blender_addon-31.2.zip
(13.48 MiB) Downloaded 332 times
