NVIDIA has confirmed that the crash introduced with the 591.x drivers has been fixed in the latest build (591.74). If you’re still experiencing crashes, please try updating to the latest Studio driver, version 591.74.
Regards
Paride
Nvidia driver
- paride4331
Anybody have already test it ?
- Elvissuperstar007
- Contact:
Please note that black screens and monitors switching to power-saving mode are still present. It is necessary to reboot the computer 5–6 times, but this can be resolved by setting Windows to Maximum Performance power mode. When using Balanced mode, monitor dropouts will occur. I am currently testing the driver; so far, everything is working fine.
- Elvissuperstar007
- Contact:
Additional observations:
If the system manages to boot successfully (usually after 4–5 restarts), it then works completely stable — for hours, days, or even a full week — without any crashes or GPU-related issues.
This strongly suggests that the problem occurs only during the early boot / driver initialization stage, not under load.
I suspect that during startup the NVIDIA driver intermittently loses the DisplayPort signal:
The computer boots and continues running,
but the screens remain black from the very beginning,
while the system itself is not frozen.
Important detail:
Entering the BIOS is always stable, with no signal loss or black screens.
The issue appears only after Windows starts loading and the NVIDIA driver initializes.
Because the system is fully stable once the driver initializes correctly, this further supports the conclusion that this is a driver-related issue, not a hardware failure.
In my opinion, this is a faulty driver behavior related to:
DisplayPort initialization
GPU power state transitions during boot
or early-stage driver resource allocation
The computer has rebooted after a critical error.
Error code: 0x00000116
Parameters:
(0xffffcf0fee12c010, 0xfffff80179d0f140, 0xffffffffc000009a, 0x0000000000000004)
The memory dump was saved to:
C:\WINDOWS\Minidump\010926-9625-01.dmp
Report ID:
50a79b67-05d4-44cf-b32c-f8748651d8e8
This driver-related bug has existed in NVIDIA drivers since August 2024.
Initially, it affected a smaller number of users and appeared to depend on specific system configurations, motherboard BIOS versions, and hardware combinations.
However, with the release of the RTX 5000 series, this issue has become widespread and systematic.
The entire RTX 5000 lineup is affected, and no fully stable driver currently exists that completely resolves this problem.
Additionally, alongside the RTX 5000 series, older NVIDIA GPUs have also begun to experience the same issue, including:
RTX 2000 series
RTX 3000 series
RTX 4000 series
This indicates that the problem is not hardware-specific, but rather a driver-level regression introduced in newer driver branches, affecting multiple GPU generations.
Important detail:
Parameters:
Report ID:
RTX 2000 series
RTX 3000 series
RTX 4000 series
I have complete shutdown of my computer, no matter the driver, no matter the Performance Power mode, no matter the time passed on a scene (it could be 10 minutes or 2 hours), but it happens everytime when I render a sequence of images. Thought it was a octane plugin's version issue but today (for the first time) I had it with the 16.10.
Could it be windows 11 related ?
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
- paride4331
Hi remKa,
If the computer is turning off and restarting, it could also be a power supply issue. Are you sure your PSU can handle your GPUs and their power spikes?
Regards
Paride
Regards
Paride
- Elvissuperstar007
- Contact:
I agree, your power supply has probably stopped holding power properly. Also, check your RAM by removing and leaving one module at a time for testing. Any memory module could be faulty.
I've cut the power consumption of my cards by 10% and everything seems to be working nicely again... I've seen a lot of posts with the same issue and this was one of the solution. Finger crossed !
Thank you for your time
- paride4331
Hi remKa,remKa wrote: Thu Jan 15, 2026 12:43 pm I've cut the power consumption of my cards by 10% and everything seems to be working nicely again... I've seen a lot of posts with the same issue and this was one of the solution. Finger crossed !
Thank you for your time![]()
This workaround might help. However, keep in mind that usage spikes may occur outside the render phase as well, for example, during denoising.
Regards
Paride
Hello, so with confidence after a full week without a crash on the 16.10, I decided to try the 16.12 and the hard computer crashes happened immediately after a render... tried the 26.04 and I had 3ds max crashes.
There is something to look at there :/
