OctaneRender for HoudiniSolaris 2025.5.0.0 [OBSOLETE]
BK
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for HoudiniSolaris 2025.5.0.0 release.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 20.0, Houdini 20.5 & Houdini 21.0 Solaris.
OctaneSolaris builds supported by this release: 20.0.896, 20.5.684, 21.0.440, 21.0.512 and 21.0.559
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "PATH_TO_OCTANE_SOLARIS_Win64 FOLDER"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "PATH": {
                "value": "$OCTVERSION\\bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION\\dso\\usd_plugins"
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
- Please run **createPackageFileForOctane.bat** for the automatic Package installer for Windows OS.
New features
To learn more about the new features and improvements of OctaneRender 2025.5 and the Render Node app, please check out (Link )
Change log since last release
  • - Unified with OctaneRender 2025.5 for Houdini production (2025.5.0.0) viewtopic.php?t=85383
  • - Fixed internal bug reports
Note: Click the link below to refer to the Important SOP to USD attribute conversion
https://www.sidefx.com/docs/houdini18.5/solaris/sop_import.html
Important notes:
[*] The minimum NVIDIA driver version required has been raised to R528 (R572 for GeForce RTX50 Series).
[*] The GPU version of Open Image Denoise is supported on Volta and Ada GPUs currently. The CPU version is used on devices with other models, and on macOS..
[*] The minimum version of macOS required is 14.5.[/b]
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
Note: Please do not use Houdini 21.0.440 and 512 build for production yet. We are releasing it as an experimental release and to collect bug reports. Also, our macOS build for Houdini 21.0 crashes on startup. SideFx is helping us to resolve this issue asap
Subscription Studio+ Downloads
OctaneSolaris [macOS](Link)
OctaneSolaris [Linux](Link)
OctaneSolaris [Windows](Link)
Demo Downloads
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
Terryvfx
I'm trying to get this running on Houdini 21 on Linux, is not my first time installing it so it's weird this issue is happening to me now.
I'm getting this error message on the console:
HdOctaneRendererPlugin not supported - removing from renderer list
Unable to create Usd Render Plugin: HdOctaneRendererPlugin
and in the log viewer in Houdini it says:
Failed to load plugin 'OctaneSolaris': libhboost_python311-mt-x64.so.1.85.0: cannot open shared object file: No such file or directory in '/media/terry/HDA/Octane_Solaris/dso/usd_plugins/OctaneSolaris.so'
PD: Plugin is running fine in the OBJ context.
BK
Terryvfx wrote: Sun Jan 04, 2026 5:13 pm I'm trying to get this running on Houdini 21 on Linux, is not my first time installing it so it's weird this issue is happening to me now.
HI Terry,
Thank you so much for reporting this issue!
We can replicate the crash on our side. We will get it fixed asap!
cheers
Kind Regards
bk3d
Terryvfx
Thanks! Seems to be an issue with H21 only, with 20.5 it's loading correctly without any changes besides switching to the corresponding built.
