2026.1 - H21.0.512 - Analytic Lights Broken + Render restarting on value change
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Aszyk
Hi there, a couple of bugs I've found in Octane 2026.1.0
Firstly Analytic Light light beams appear to be broken - when light beams are enabled in Post Processing, the render is fully black. Changing the Medium density doesn't fix this.
I tried this using the Octane Render Setup SOP and a Octane ROP node in the ROP context.
Secondly changing any value in the Render Target (again in SOP setup and material context) causes the render to restart, even values such as Hotpixel removal and Exposure for instance will trigger an IPR refresh.
Windows 11 Pro - 24H2 - 26100.7462
NVidia 4090 x 2
112GB Ram
NVIDIA Studio Driver 591.44
Oct Standalone 2026.1
Plugin version 2026.1.0
Houdini 21.0.512
Win 11 64 | RTX 4090 x 2 | AMD Threadripper 3970X 32-Core Processor 3.70 GHz | 112 GB RAM
https://www.nealcoghlan.com
dom_otoy
Heyo!
Sorry for the delayed response!
We fixed the render restart issue.
Also regarding the black post pass - this is a core bug when the analytic light is set to 180 degrees. Lowering this value fixes the issue.
We have changed the defaults since to match the SA defaults.
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
Return to “Bug Reports”
