OctaneRender™ for Blender 2025.5 - 30.11 FINAL Custom-Built Release [STABLE]
azen
IMPORTANT NOTE: This will be the final "Custom-build" version of the Blender plugin. This Release will still be maintained for the foreseeable future, otherwise this is expected to be the very last version of the Blender plugin to use a custom-built version of Blender.
CHANGES SINCE LAST RELEASE
  • Updated to Octane 2025.5
  • Updated to Blender 4.5.5
FIXES SINCE LAST RELEASE
  • Minor bug fixes
HOTFIXES 30.11 (19/02)
  • Updated version number of Blender Octane Edition to 30.11
  • Refactored the OSL value structure to fix missing value issues in Blender 5.0
  • Added support for macOS 14.5 as the minimum requirement
You can read about new features of OctaneRender™ 2025.5 here:
viewtopic.php?t=85294
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.11 (4.5.5)
Octane Server - Studio+ Edition - 30.11
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
