Octane 2026.1 for Cinema4D - v1.8.2
ChrisHekman
Hi all,
Here is another bugfix build. The main reason for this build were error popups on the mac build and a couple of other issues.
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.1 - v1.8.2 plugin revisions
Changes
  • Fixed (false) errors in the macOs build
  • Closing the LV now guarantees Octane stops rendering in the background
  • Layout changes no longer incorrectly reset the Octane Settings - this can still happen in C4D 2026.0! Upgrade C4D 2026.1 if this happens.
  • Object layers now use correct color again
  • Displacement defaults to normal for now. This might change in the future as the new displacement system improves
  • Refactored distorted UVW projection pins to more closely align to Octane
Downloads:
WINDOWS STUDIO+ 2026.1 - v1.8.1 (R21-R2026)
Installer: https://render.otoy.com/customerdownloads/plugins/d6/98/5b/36/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8.2.exe
Archive: https://render.otoy.com/customerdownloads/plugins/3c/5d/0d/75/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8.2_Bundle.zip
MacOS Prime 2026.1 - v1.8.1 (R21-R2026)
Archive: https://render.otoy.com/plugindownloads/0b/ef/9f/d4/OctaneRender_Prime_2026.1_for_Cinema4D_v1.8.2.zip
WINDOWS DEMO 2026.1 - v1.8.1 (R21-R2026)
Installer: https://render.otoy.com/plugindownloads/b1/03/df/41/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8.2.exe
Archive: https://render.otoy.com/plugindownloads/e2/8b/aa/c7/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8.2_Bundle.zip
2026.1 - Nodes
Installer: OctaneRender Studio+ 2026.1 Node for Windows (installer)
Archive: OctaneRender Studio+ 2026.1 Node for Windows (ZIP archive)
Linux: OctaneRender Studio+ 2026.1 Node for Linux
2026.1 - v1.8.1 plugin revisions
Changes
  • Fixed issue where Displacement Height increased every time a C4D scene was loaded.
  • "Use Denoised Beauty" now works correctly again.
  • Octane Settings now load properly when the settings window already existed in a C4D layout preset.
  • Octane logging options now work correctly again.
  • Neural Radiance Cache setting now works correctly and no longer causes logging errors.
  • Fixed Anisotropy/Index map logging errors.
  • Octane Baking Camera no longer causes logging errors.
  • Fixed PBR Material logging error.
  • Fixed issue where some copied nodes appeared white.
  • Corrected Post Processing pins UI.
  • Removed "expires in X days" from the Live Viewer when no expiration applies.
  • Fixed OpenPBR logging errors
  • Fixed MaterialX image nodes logging errors
  • Fixed issue where float pins UI had a stepsize of 1 when they shouldnt
2026.1 - v1.8 plugin revisions
  • Major Changes
    • Updated to Octane 2026.1
    • Support for C4D’s User Data Tag (via AttributeTex node)
    • Mograph Data support (via AttributeTex node)
    • Added OpenPBR Material
  • Material Changes
    • IOR is now a texture input instead of a float
    • Anisotropic is now a texture input instead of a float
    • CMYK added Halftone texture node
    • Added MaterialX nodes: Fractal2D, LatLongImage, HexTiledImage, and HexTiledNormalMap
    • Added displacement node quality pin
    • Added Sheen BRDF
    • Added Oren–Nayar (energy preserving) to BRDFs
    • Improved UI layout for various nodes and objects
  • Scene & Geometry
    • Added TraceSets to Octane Lights and Environments
    • Improved Meshlets support
    • Updated Vectron Object variables for 2026
    • Added new pins to Gaussian Plat Object: Clip Bounds Transform, Clipping mode, Priority,
  • Textures
    • Added Virtual Texture option to texture nodes
    • Known issue: Virtual textures make material previews render black
  • Settings
    • Added UI for new Upsampling settings on the imager
    • Added Kernel compatibility modes
  • AOV
    • Added new nodes: Cryptomatte Mask, Expand/Contract, Reblend, Unblend
    • Added Environment (unoccluded) render AOV
    • Added PostFX media AOV
    • Added “Lock render” option to AOVs
    • Added “Effects” to multiple AOV nodes
    • Renamed Checkpoint → Snapshot
    • Various minor text/name updates
    • Added "Info/Gaussian Splat Info AOV"
    • Added "Beauty – Other/Gaussian Splat AOV"
    • Adding an Alpha AOV in the Render AOV Tab now works correctly
  • Fixes
    • Fixed infinite VP rendering with Use denoised beauty pass + info channel
    • Fixed crash related to image tiles
    • TraceSets now work properly in the Picture Viewer
  • Known Issues
    • Virtual textures make texture/material previews render black (but work in Live Viewer)
    • Duplicate "Open In Editor" button in PBR material basic tab
    • Mac has an incorrect renderfailure detection error when there is no render failure:
      "<<< Render failure detected!!! >>> Please check render statistics to solve the problem."
    • Gaussians splats have a wireframe material - this might be removed at a later date
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
VladaStevanovic
Displacement - Nromal ( baked resoluton 4096)
Displacement - High
As you can see in the attached images, besides the fact that the new displacement is very slow, the results produced by the same Noise are also different
ChrisHekman
VladaStevanovic wrote: Tue Dec 16, 2025 4:55 pm Displacement - Nromal ( baked resoluton 4096)
Displacement - High
The Normal mode ignored texture settings. It will take your texture linearly.
The High mode will take into acount texture settings like sRGB, Power, Legacy Gamma etc. Results should be the same if you use Linear SRGB and a gamma of 1 and a power of 1 in your input texture node.
Waarp
I have a big VRAM problem with both this version and the previous 1.8.1. if I try to render above 4k the VRAM usage increases exponentially. above 7k even all the available 24gb are used up. is this a known problem? Thank you
ChrisHekman
Waarp wrote: Wed Dec 17, 2025 4:17 pm I have a big VRAM problem with both this version and the previous 1.8.1. if I try to render above 4k the VRAM usage increases exponentially. above 7k even all the available 24gb are used up. is this a known problem? Thank you
This seems to be an issue in Octane core. I have fowarded the problem to the Octane Team
astrofalcon
Getting very consistent crashing with this latest build and C4D 2026.1. Main cause is when I'm switching 2 or more c4d scenes. This is what Gemini thinks "The crash log is 100% conclusive: it is nvcuda64.dll failing during oidn_init_module_device_cuda (Octane AI Denoiser initialization)." I'm not so sure because I've tried disabling all of the denoising features and still will get crashing.
Really would like to run these newer builds. Crashing only started after I updated C4D to 2026.1 and Octane v1.8.2. 2026.0 + Octane v1.7.2 was quite stable.
More info from Gemini "I analyzed your new _BugReport.txt and the smoking gun is right there in Thread 15000: octane.dll calls oidn_init_module_device_cuda_v20303 -> nvoptix.dll -> nvcuda64.dll (CRASH)"
Okay, update here (Octane 2025.4 for Cinema4D - v1.7.2) is rock solid on my system with C4D 2026.1 and NVIDIA Studio Driver 591.44. I can't make it crash if I try. So I think it's safe to say the bugs are in this build (Octane v1.8.2) Happy to share some scenes and explain in more detail everything.
Please let me know how I can help you guys fix this!
ChrisHekman
astrofalcon wrote: Fri Dec 19, 2025 7:05 pm Getting very consistent crashing with this latest build and C4D 2026.1. Main cause is when I'm switching 2 or more c4d scenes. This is what Gemini thinks "The crash log is 100% conclusive: it is nvcuda64.dll failing during oidn_init_module_device_cuda (Octane AI Denoiser initialization)." I'm not so sure because I've tried disabling all of the denoising features and still will get crashing.
Yes if you could share some scenes with me + reproduction steps that would be great
haineicunzhiji
I verified this with my other friends.
And I tried each version one by one, and finally arrived at:
## Versions after 2025.2.1 for PSD output:
1. The thumbnails are blank;
2. Versions before 2025.2.1 have normal thumbnails;
3. Dragging the PSD into different versions of Photoshop may cause the Photoshop to crash;
4. My Photoshop 2025 will pop up a window and crash;
5. My Photoshop 2026 will simply freeze;
6. My Photoshop 2024 can open it!
7. However, some of my friends' Photoshop 2025 and 2026 can open it, while some will crash;
8. Although my friends can open it, the PSDs generated by these three newer versions (OC) of them also have no thumbnails.
The PSD files output by the three new versions of OC do not have thumbnails.
The PSD files output by the three new versions of OC do not have thumbnails.png (10.47 KiB) Viewed 6814 times
I caused a crash in Photoshop 2025 by using the PSD file outputted by OC 2026.1.
## Summary:
1. PSD output from versions after 2025.2.1 has no thumbnails, which is a definite problem;The reason is that there is an additional "RootAlpha"?
2. PSD output from versions after 2025.2.1 may not be opened in different versions of Photoshop and may cause Photoshop to crash, which is an uncertain issue;
3. Starting from the version after 2025.2.1, the layers of the PSD files produced all have a white mask added. Why is that?
Starting from the version after 2025.2.1, the layers of the PSD files outputted all have a white mask added..png
PSD with thumbnail and PSD without thumbnail
The PSD file output in version 2025.2.1 contains thumbnails.psd.zip
(1.5 MiB) Downloaded 112 times
Versions released after 2025.2.1 do not have thumbnails for the PSD files.psd.zip
(1.5 MiB) Downloaded 110 times
The PSD file is output as blank and causes the PS program to crash.zip
c4d project
(71.13 KiB) Downloaded 82 times
C4D 2025.3.3 @ win11|i7-14700k|Geforce RTX4080super|64GB
eyeonestudio
About OpenPBR....
1. When applying an OpenPBR material, the Texture Tag's Projection is changed to Spherical instead of UVW.
2. In the Material Editor, the Assignment section is positioned at the top.
3. In the Node Editor, the Open Node Editor button appears duplicated. It would be better to maintain consistency with other materials.
AWOLism
Hi! I am experiencing a couple of issues when opening older files in the latest Octane version.
What I have found so far (when opening a file last saved in 2021) :
- All Image Texture nodes get their Color Space set to "Non-color data", regardless of the previously saved setting. This of course leads to huge color problems especially with diffuse textures. This forces me to manually rework of every single Image Texture node.
- All Universal materials have their Transmission mode set to "Diffuse" even when previously created as "Specular".
This is very suboptimal for dealing with older files, which I tend to do on occasion. On bigger projects it's a pretty catastrophic time waste to manually re-adjust every material.
As I have a new 5090 card now, I don't believe I can run any Octane version older than 2025, is that correct? Otherwise I could have just run a parallell install of an older version.
Could this be made more backwards compatible?
Thanks!
/ Andreas
C4D R2026 + Octane 2026.1 | Windows 11 Pro | 128 gb ram | 1 x RTX5090
