OctaneRender™ for Blender 2025.4 - 30.8 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Octane 2025.4
  • Updated to Blender 4.5.4
FIXES SINCE LAST RELEASE
  • Minor bug fixes
You can read about new features of OctaneRender™ 2025.4 here:
viewtopic.php?t=85139
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.8 (4.5.4)
Octane Server - Studio+ Edition - 30.8
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
