Hello, did somebody have run to similar problem, and is there a way to resolve it?
Octane Imager (Render Mode) is not loading presets, and is fully greyed out.
Imager Presets drop down menu - *Missing Paths*
Imager preview mode and render mode are not checked simultaneously.
Though Octane Imager (preview mode) seems to work fine
Versions:
OctaneBlender30.7.0
OctaneServerStudio30.7
So far, I have tried to show a direct ocio.config file in the preferences > add-ons >blender octane > color management
Any help would be appreciated <3
Octane Imager (render mode) - missing paths
- linograndiotoy
If "Use for All Cameras" is enabled, you'll be able to edit (and use) the Imager options directly in the 3D View.
If it's disabled, the Imager settings become available individually in each camera’s properties panel.
As for the presets: Octane Imager Presets do work, but they don’t come preloaded — you'll need to create and save them manually before they appear in the dropdown.
Thanks! Checked those, but the issue persists.
Even if both Use for all cameras (Imager) and Octane Imager (Preview mode) are disabled in the viewport, Imager in camera settings is still greyed out.
Even I save a preset, and the toggle is on, all menu is greyed out.
Is there something else I may be missing?
- linograndiotoy
Could you please share a scene and a video showing the issue?
