OctaneRender 2026.1.Alpha 3 for Houdini Alpha (2026.1.Alpha_3.3)
bruce.chai
This is a alpha release of the OctaneRender™ 2026.1.Alpha_3.3 for Houdini™ plugin compiled with the Octane 2026.1.Alpha 3 core. This 2026.1.Alpha_3.3 release is available for the latest Houdini production builds on Windows x64, Linux.
Houdini production builds supported by this release: 20.0.896, 20.5.613, 20.5.654, 20.5.684, 21.0.440.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
New features
To learn more about the new features and improvements of OctaneRender 2026.1.Alpha 3, please check out the 2026.1.Alpha 3 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2026.1.Alpha_3.3 Studio+ license
Windows Houdini 20.0.896
Windows Houdini 20.5.613
Windows Houdini 20.5.654
Windows Houdini 20.5.684
Windows Houdini 21.0.440
Windows Houdini 21.0.512
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.613 (gcc11.2)
Linux Houdini 20.5.654 (gcc11.2)
Linux Houdini 20.5.684 (gcc11.2)
Linux Houdini 21.0.440 (gcc11.2)
Release Notes
RELEASE 2026.1.Alpha_3.3
PLUGIN FEATURES AND FIXES:
  • Added "Distorted UVW" node
  • Supported new rgb image output color option
  • Supported pin/parameter folders to VOP/Material nodes
  • Avoid reloading unchanged polygon mesh object's geometry after scene frame changes
  • Fixed scatter on surface loading problems
  • Fixed Volume Ramp max vlaue parameter doesn't work
  • Added Volume to Texture node
  • Changed default log level to Error
  • createPackageFileForOctane.bat update: Added a section that checks for the old solaris.json file existence. If this is found, then it will ask to remove this file, as it can create issues, and WILL stop the plugin from working
  • Rendertarget and Rendersetup hda update: Updated the "ACES tone mapping" tooltip to remove version specific information (used to be 1.2 but will be changing version to version)
  • Reimplemented volume feature
    1. New volume object parameters
    2. Faster VDB grids loading
    3. No more extra absorption and scatter grids after loading (meaning smaller memory size)
    4. Set Voxel size correctly
    5. Support extra grids like Cd grid
    6. Support velocity vector grid
    7. Fixed vdb volume sop level transform offset
OctaneRender for Houdini tutorial
Still updating
Note
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "<path_to_plugin_directory>"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "HOUDINI_MENU_PATH": {
                "value": "$OCTVERSION/config/Menus"
            "HOUDINI_SCRIPT_PATH": {
                "value": "$OCTVERSION/scripts"
            "PATH": {
                "value": "$OCTVERSION/bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION/dso/usd_plugins"
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package.
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
dom_otoy
NOTES ON THE VOLUMES: While we are working on improving these things there are currently some limitations to the Octane volumes implementation:
1. You can only have one volume set of grids per object (density, temperature, vel etc).
If you have multiple volumes please split them into seperate objects using an object merge.
2. Packed primitives & packed instances are not supported at the moment. For instancing use the instance obj node.
3. All grids need to have the same voxelsize, so mismatched grids (for ex. halfres velocity grids)
are not supported. You can use the vdb resample node using your density grid as a reference,
or disable resampling on the output tab of the pyrosolver node.
4. There is an issue with the volume motion blur, where you have to significantly increase
the velocity scale to get appropriate results.
We are working on improving these things. In the meantime one workaround for #3 and #4 is
to export your volume to a vdb file sequence using the file cache node and load it
using the vdb file mode. This should have better loading efficiency in some cases,
has accurate motion blur scale and supports mismatched grid resolutions.
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
akvahouse
Good afternoon, I have a problem with volume denoise. When I enable this option, my computer just crashes. Perhaps it depends on the version of the Nvidia drivers. Could you recommend a stable version or some kind of workaround? I currently have version 581.80 of the Game Ready drivers installed.
Denoise works perfectly in Cinema 4D, so I don't think it's a driver issue. Plus, the interface responsiveness is much higher in Cinema 4D. I don't know why that is, but even though the volume is the same, everything feels much faster.
Win 11 x64 | Amd threadripper 1950x | 128gb | Rtx 3090ti
jan8
can i please ask for a build for h21.0.512?
fanks!
dom_otoy
jan8 wrote: Tue Nov 25, 2025 4:19 am can i please ask for a build for h21.0.512?
fanks!
Hey!
We are currently working on the beta2 build. Should be out pretty soon - and this will include the latest Houdini release!
Happy Rendering!
vurt
Hi guys, when can we expect the 2026.1.0 release?
