OctaneRender 2026 Alpha 3 for Cinema4D - v1.7.0
ChrisHekman
Hi all,
Here is our first 2026 Alpha release!
Please note that this is an experimental alpha both for Octane and for the Octane C4D plugin. Octane features and Plugin implementations will be subject to change.
For the next release (1.7.1) we will be focussing on stability and fixes, if you have pressing issues you want fixed, let us know.
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026 Alpha 3 - v1.7.0 plugin revisions
Octane 2026 Changes:
  • Added Meshlets (Experimental). Accessable via the Octane Object Tag
  • Added Tracesets. Accessable via the Octane Object Tag
  • Added Gaussian Splats
  • Added MaterialX nodes (Experimental)
  • Added Vectron operators
  • New Texture Displacement (Experimental). There is a currently a stability issue with the new texture displacement in Octane.
Changes:
  • Octane Object tag on a clonder is now applied to its cloned items (if they dont have object tags of their own)
  • Cloners in Multi-Instance mode now correctly displayed in a Custom AOV
  • Chaos Texture performance improvements. (Underlying issue is still present in Octane, we are currently investigating a permenant solution)
  • Fixed issue where converted RS materials used absolute paths to osl scripts
  • Z value of noise4d node is now also scaled
  • Improved converting Universal material to Sub-Material
  • Color Picker in the Live-Viewer works again
  • Changed utility default color
  • Rearranged Vectron Menu
  • Submaterials now use spheres as preview
  • Custom AOVs do not lose custom naming after being packed with the C4D Wizard anymore
  • Fixed a bug that prevented creating a Render Region after rendering in PV
  • "Get Last Region From Live View" command now correctly updates the right border value
  • Removed "Tag" from "Octane Rest Position Tag"
  • Standard Surface Material: Subsurface Scale slider max value changed to 1000
  • Standard Surface Material: Opacity Slider now correctly set to 1.0 by default
  • Shape field is now hidden on Texture Fields when it is not used
  • Dynamic pin/port are now numbered correctly (Effects decal objects)
Downloads:
WINDOWS STUDIO+ 2026 Alpha 3-v1.7.0 (R21-R2025)
Installer: https://render.otoy.com/customerdownloads/plugins/89/36/5f/75/OctaneRender_Studio%2B_2026.1_Alpha_3_for_Cinema4D_v1.7.0-beta1.exe
Archive: https://render.otoy.com/customerdownloads/plugins/1a/bf/87/68/OctaneRender_Studio%2B_2026.1_Alpha_3_for_Cinema4D_v1.7.0-beta1_Bundle.zip
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
cjadams
Is there a mac build? also a matching render node build?
Sorry, no macOS version for 2026.1-Alpha3,, and the same is for Render-Node versions:
We need to wait for next release.
ciao,
Beppe
jmachemer
So I have been getting a really annoying error/s.
First off, I am on a PC (Ryzen 9 7950X, 1500W PSU, 4090 Founders Edition, 64 GB of ram, Windows 11) and am running C4D 2024.4.1.
I double checked all the source of CUDA errors before launching this version of Octane (OOC, VRAM, Nvidia Studio Drivers, etc) but unfortunately, every time I hit render, I get CUDA errors now.
Another odd issue is that I get errors saying I need to reduce polygon count in my scene. But isn't that the whole reason for Meshlets in the first place? Shouldn't Octane be able to handle more polygons now than ever before? And my larger question as a follow-up to that is...why would an older version be able to handle the same exact file, while 2026 errors out based on polygon count?
And third on the list...when I tried using the Octane tag to enable meshlets, it never worked. I pressed update, it would put a location of the meshlet file in the text field, but then when trying to render, it would error out.
Is there any official documentation yet on how to use Meshlets functionality properly so that we know we are setting it up correctly?
Thanks - Joel
Hi Joel,
Meshlet should work as you have described, just click on "Update Meshlet ID" to create an ID, then click on "Enable meshlet" checkbox, and wait until the engine has prepared the reduction.
Here is an example applied to a scanned .obj statue:
But please consider that this is an Alpha build, so stability is not expected.
Could you share your mesh so we can have a look?
ciao,
Beppe
ChrisHekman
jmachemer wrote: Thu Sep 11, 2025 11:48 am So I have been getting a really annoying error/s.
Thanks - Joel
Could you share those errors with us? Preferably the logs?
CCIDgfx
There's something weird going on with materials in this release. I reinstalled the last stable version and it's fine. Materials used were from RDT, Quixel and GSG
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
Amaterasu
Hello everyone, I've been wondering for a long time when the problem with vdb containers will be fixed. The problem is that when I use ctrl+z or copy a container using ctrl, Cinema freezes. Maybe I'm doing something wrong? Or is this really a problem that hasn't been solved yet?
macray
I'm not sure what I miss but this plugin does not appear in Cinema4D 2026 for me.
when using the windows .exe installer to install it - it detects my c4d R21 and R2025 but nothing for the most recent 2026 version and it does not appear in 2026.
do I need to specify something in the preferences of c4d for this version?
wait, does this -2026- refer to Octane or Cinema? I just checked the bundle version and saw there is not even a c4doctane-2026 xdl file...
Octane running @ Dell Precision laptop with nVidia quadro/ ada gpu
Hurricane046
macray wrote: Thu Sep 18, 2025 7:28 am I'm not sure what I miss but this plugin does not appear in Cinema4D 2026 for me.
Since C4D 2026 was released on Sep 10 and this particular Octane version was released on Sep 03 I believe it's not possible to run it on the 2026 C4D version. I'm running into the same issues as you are and since the 2026 .xdl file is not present it's reasonable to assume we'll need to wait for another Octane version.
