when trying to render in live view port it carches
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
k.w.b2
MacOS 15.6
M4 MAX (memory 36 GB)
Octane 2025 - v1.61
CPU 14 Core - GPU 32
Using: Cinema 4D 2025.3.3
OctaneX: OctaneRender_Prime_2025.2.1_for_Cinema4D_v1.6.1
report:-
Started logging on 17.08.25 23:35:26
Octane X Prime 2025.2.1 (14020100)
initOCIOconfig cfgFile: OCIO_ENV:
disableAllDevices
VRAM used/free/max:0Kb/36Gb/36Gb Out-of-core used:0Kb RAM used:16.84Gb total:36Gb OpenGL free/total:0/0
--------------------------- EXPORT LOG ---------------------------
Export materials time= 33575.785 ms
*** Calculating motion blur on frame:42
*** Calculating motion blur on frame:43
TIMES=42 43 motionCnt=1856/20000 timeps:0.001 MT:0 Time=135.146 ms.
Collect objects time= 206.68 ms
Mesh creation time = 1846.341 ms.
Api update time: 49.108 ms.
Compute warning 256:2755787658322969814:60 on device 0: Out of memory
MB:1/1 ST/MOV:0/1275 Nodes:2741 Tris:37.74m DispTris:0 Hairs:0 Meshes:1k
Textures Grey8/16:12/0 Rgb32/64:142/8
Already OC Live is activated
Deleting texCache folder... Library/OctaneRender/cache/texCache
disableAllDevices
File not found: Library/Preferences/Maxon/Maxon Cinema 4D 2025_FFA38A4B/updates2020.txt
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Octane: MB:1/1 ST/MOV:0/1275 Nodes:2741 Tris:37.74m DispTris:0 Hairs:0 Meshes:1k
Octane: Textures Grey8/16:12/0 Rgb32/64:142/8
>> ProcessUpdate(flags=CMOG cAsyn=1 dDelay=1
>> ProcessUpdate end res:0 tm:0.002ms.
from the log, it seems that the scene is too complex for your mac, and you have not enough memory.
Cold you save the scene with assets, and share a link to the scene via Private Message?
ciao,
Beppe
Return to “Bug Reports”
