OctaneRender™ for Blender 2025.2.1 - 30.6.2 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.5.1
  • Added support of Octane Camera Projection and Transform nodes
  • Added support of Geometry Group Node Support in Shading System
  • Added the Toon Edge Shading Kit in the preferences panel.
FIXES SINCE LAST RELEASE
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.3 here:
viewtopic.php?t=85028
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.6.2 (4.5.1)
Octane Server - Studio+ Edition - 30.6.2
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
