Cinema4D version 2025.2.1 - v1.6.1 Hotfix
ChrisHekman
Hi all,
This is a hotfix for the 1.6 build. Mainly it fixes AOV node connections from dissapearing when loading scenes from older versions
Sadly if you saved your AOV graph with 1.6, it will break in this build again - our apologies for any inconvenience.
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2025.2.1 - v1.6.1 plugin revisions
Changes:
  • AOV node connections no longer dissapearing when loading scenes from older pluign versions
  • Fixed RS converted material breaking in certain situations, they now no longer use absolute paths for certain OSL scripts
  • Tab behavior works correctly again in RGB UI on Octane nodes
  • OctaneRender PV: Fixed non responsive/resetting sample count
  • OctaneRender PV: Fixed Infinite hang when denoised beauty is requested when rendering info
Downloads:
WINDOWS STUDIO+ 2025.2.1-v1.6.1 (R21-R2025)
Installer: https://render.otoy.com/customerdownloads/plugins/c5/ef/4f/f8/OctaneRender_Studio%2B_2025.2.1_for_Cinema4D_v1.6.1.exe
Archive: https://render.otoy.com/customerdownloads/plugins/b0/57/36/b3/OctaneRender_Studio%2B_2025.2.1_for_Cinema4D_v1.6.1_Bundle.zip
Mac OSX Prime
Archive: https://render.otoy.com/plugindownloads/07/0e/79/38/OctaneRender_Prime_2025.2.1_for_Cinema4D_v1.6.1.zip
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
UON.Visuals
I have a chance to update before the next long render, does this fix the render node issue where some of my nodes would fail immediately?
Screenshot 2025-05-20 235454.jpg (7.47 KiB) Viewed 7289 times
Really excited to try some new C4D 2025.3 features!
Also, can you recommend the best Nvidia driver version with RTX 5090? I'm getting an insane amount of crashes on my main machine after needing to update from stable studio driver 552.22.
hoffwerr
There's a little bit of an annoying behavior with the Render AOV Manager saving path.
If there's a project in let's say "J:\Project\ABC\Project.c4d" and you use the standard Save options of C4D with the File set as "$prj". It'll save it in "J:\Project\ABC\Project.exr"
The Render AOV Manager saves it in "J:\Project.exr". Kinda annoying as I generally only use tokens. I need to include the full path to not have it saved it elsewhere.
Any chance we can have that fixed in the next release ?
Kalua
Thanks, team!
Looks great here so far.
Could you guys please implement the Memory Pool graphic just like Octane Standlaone provides? It is really helpful for 2x3090 + Nvlink Setup.
Been asking for this for over 2 years now, 30xx series still relevant, specially with 40xx and 50xx catching fire with power connectors.
Regards,
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
iDani
I Think the Denoiser is not working while rendering to pictuerviewer. Not on PC and also not on Mac. In liveviewer it is still working.
cheers Daniel
Kalua
iDani wrote: Tue Jul 15, 2025 3:22 pm I Think the Denoiser is not working while rendering to pictuerviewer. Not on PC and also not on Mac. In liveviewer it is still working.
cheers Daniel
Wow... you are right.
Was working till last version.
I am rendering an animation pas 2 days. Till now u mentioned I checked it. And it is true. Denoise Beauty is not working in Render Production. Only Live viewer.
Kalua wrote: Tue Jul 15, 2025 11:13 pm
cheers Daniel
Sorry guys but I'm not able to reproduce the Denoiser issue in Picture Viewer here, in both Mac and PC.
I've tried both Octane AI Denoiser and Open Image Denoiser, in different file formats, with multi layer enabled and disabled, but Denoised beauty AOV was always saved correctly here.
Could you share an example scene that shows the issue?
ciao,
Beppe
iDani
bepeg4d wrote: Wed Jul 16, 2025 8:00 am
cheers Daniel
ciao,
Beppe
Hi Beppe,
here is a file to test the denoising. But every file will not work since last update.
cheers Daniel
test_Denoise.zip
(6.15 MiB) Downloaded 132 times
jeickholt
There is an issue with this release. It's freezing during renders and I have to force quit C4D. I had to roll back to Octane Render Studio for Cinema4D 2025-1 Build0104.
jeickholt wrote: Wed Jul 16, 2025 9:06 pm There is an issue with this release. It's freezing during renders and I have to force quit C4D. I had to roll back to Octane Render Studio for Cinema4D 2025-1 Build0104.
Please share the scene that is giving you stability issues.
You can share a link via Private Message to me, if the scene is sensitive.
ciao,
Beppe
