OctaneRender™ for Blender 2025.2 - 30.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated version number to 30.4
  • Updated to Blender 4.4.3
  • Updated to Octane 2025.2
  • Added Alpha AOV Node
  • Added Denoiser Quality in Camera Imager Node
  • Added compatibility mode in Post Process Node
FIXES SINCE LAST RELEASE
  • Fixed: Stereo Camera Options Are Always Grayed Out
  • Fixed: Fixed BP-140: Octane Object Properties missing for Hair Curve object
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.2 here:
viewtopic.php?t=84788
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.4 (4.4.3)
Octane Server - Studio+ Edition - 30.4
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Blender Octane Edition - 30.3 (4.4.3)
