OctaneRender 2025 for AutoCAD [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for AutoCAD TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date. If in doubt, run Octane Standalone, then add and click on a Rendertarget to make sure it starts rendering.
2) If the Octane Camera direction does not match up with the AutoCAD camera, Rightclick the XYZ axis in the AutoCAD viewport and select "World".
3) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
AutoCAD Version
The plugin requires AutoCAD 2026, Windows 64bit.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win 7, 10 or 11)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- AutoCAD version and build number
- OctaneRender for AutoCAD version (ie. 2022.1)
For more information...
- Specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/AutoCAD/?page_id=661
- Read the on-line manual
- Read the (Link FAQ)
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Download Links
Current STABLE build (Octane 2025.3 - AutoCAD 2026)
Previous STABLE build (Octane 2025.2 - AutoCAD 2022-2024)
Release Notes
2025.3.0.36 (30-Sep-2025)
- Compiled with Octane 2025.3
- Added support for AutoCAD 2026. Removed support for AutoCAD 2022-2025
2025.2.0.35 (21-May-2025)
- Compiled with Octane 2025.2
- Added the "UV coordinate with transform" node
- "Ray Step Increase Factor" pin has been added to the Medium nodes
- Updates to the "Chaos texture" node
- 11 New blend modes for output AOV layers
- Changed the maximum and default values for all kernels for "Parallel samples" and "Max. tile samples" pins.
- Added the "Camera mask" render pass
- Added option to the "Metallic Reflection Mode" pin of the "Metallic Material" node
- Add the "Pre-multiplied Alpha" pin to the "Output Aov"->"Blend"->"Texture" node
- The "Realistic lens camera" has been added - however the Aperture cannot be set by the plugin, so the FOV does not match with Octane.
- Not Implemented: Decals
- Not implemented: Mesh Vertex Rest Positions
- Added new Render AOV -> Alpha node
- Added a new pin Denoise Quality to the Camera->Imager and Output AOV->Open Image Denoise nodes
I have updated the installers at the top of this thread with:
2025.3.0.36
I have posted the Octane 2026.1 build of the plugin to viewtopic.php?t=85325
There will be not further Octane 2025 plugin builds.
Return to “Autodesk AutoCAD”
