OctaneRender™ for Blender 2025.1 - 30.3 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated version number to 30.3
  • Updated to Blender 4.4.1
FIXES SINCE LAST RELEASE
  • Fixed: Z-Depth looking weird in Preview (Mac Version)
  • Fixed: ORBX exporter cannot work with objects with "render mode" settings
  • Fixed: Real Lens Chromatic Aberration Value Is Multiplied by 100 When Exported to ORBX
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.1 here:
viewtopic.php?t=84667
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.3 (4.4.1)
Octane Server - Studio+ Edition - 30.3
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
