Tips for Optimizing Render Settings in Octane for Blender?
briansbergeron
Hello everyone,
I’m using OctaneRender to render animations in Blender, but the render time is quite long.
Could anyone share their experience or best practices for optimizing Kernel and Render Settings in Octane? I want to reduce render time while maintaining good image quality.
Thanks in advance!
sunrisesushi
I’ve been in a similar situation with Octane in Blender, and render time can really add up quickly depending on kernel settings. One thing that helped me a lot was switching between Path Tracing and PMC depending on the scene—Path Tracing is usually faster for most cases, especially if you keep samples under control and use denoising instead of pushing samples too high.
Also, lowering GI clamp can help reduce fireflies without needing excessive samples, which indirectly speeds things up. In the render settings, try enabling adaptive sampling if you haven’t already—it stops rendering noisy areas early and saves a lot of time. For animations, keeping motion blur and heavy depth of field under control can also make a big difference.
Finally, optimizing textures (using lower resolution where possible) and reducing unnecessary light bounces usually gives a good balance between speed and quality. Octane is very powerful, but small tweaks in kernel settings can easily cut render time in half if tuned properly.
marlin274
I’ve had the same issue with Octane in Blender—render time adds up fast depending on kernel settings.
Please have a look at the following videos by Raphael Raü/Silverwing on how to optimize lighting materials, and render settings to reduce noise and have faster rendering in OctaneRender.
https://youtu.be/vG8rGIKX16U?si=1Pk6Pe_CqexlRSLA
https://youtu.be/zSln22ss_LM?si=i2zx3wYBA_Pllhq7
https://youtu.be/OxaroYqHEQ0?si=u2zOjS0Lm_cpNglf
It is for c4doctane, but the concepts are the same for any plugin or even Standalone.
Happy GPU rendering!
ciao,
Beppe
