OctaneRender™ for Blender 2025.1 - 30.2 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.4
  • Updated to Octane 2025.1
  • Added Inputs to the Toon Ramp (Similar to Gradient Map)
FIXES SINCE LAST RELEASE
  • Added missing Diffuse and Emission nodes in Spotlight's node tree
  • Fixed Issue: Occlusion AOV Update Issue
  • Minor Bug fixes
HOTFIXES 30.2.1 (16/04)
  • Updated version number of Blender Octane Edition to 30.2.1
  • Fixed: Instanced Light Transformations Not Updating in Octane Preview
  • Fixed: Material Converter not working (30.2)
  • Fixed: Texture Node (AOV and Compositing) Missing "Add Parameter" Option
You can read about new features of OctaneRender™ 2025.1 here:
viewtopic.php?t=84667
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.2.1 (4.4)
Octane Server - Studio+ Edition - 30.2
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Blender Octane Edition - 30.2 (4.4)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
