OctaneRender for Maya 2025.1-24.4 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2020, 2022, 2023, 2024 and 2025 64-bit on Windows and Linux systems. Maya 2024 and 2025 on macOS (ARM only).
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone
Important: if using macOS, we strongly recommend that you update to version 13.3. Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
Changes since version 24.3:
  • Integrated the 2025.1 rendering engine.
Subscription Studio+ Downloads
OctaneRender for Maya Studio+ [Windows]
OctaneRender for Maya Studio+ [Linux]
Prime Downloads
OctaneRender for Maya Prime [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
mintychap
Hi, I'm testing using this Maya build on an new Studio M3 Ultra and am having an issue with the dirt node which is not working. I get this message as you adjust the sliders:
"Can't write int to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x5e4e32130)" .
The dirt node appears to work in 2025.1 standalone, just not the plugin.
Same issue using Maya 2024, 2025 and also with the last 2024 build.
Other issue so far is not connecting to the LiveDB
Any Idea's what the issue is?
Mac Stusio M3 Ultra 256GB
Sequoia 15.3
Maya 2024.2
I will check this, thank you for report.
Vyoor
Hi!
What's about Maya 2026 support ? ;)
Cheers
i7, 4x GTX 780, Maya.
We're on it. It will be implemented in upcoming versions.
Locked
