Octane Parm in Dome Light Creates Two Visibility Tabs
Sub forum for bug reports
liamclisham
The Octane Parms in a dome light has to visibility tabs with additional cast shadows and light pass id check box. This is causing Dome Lights to not work with light passes.
dom_otoy
Hey Liam!
Thanks for the bug report.
I was able to confirm the issue.
You are able to disable the dome light using the "environment" light pass.
That being said the two visibility tabs are definitely a bug, and either we need to make the light passes work, or if this is a limitation that it only works via the environment pass, we need to remove those options.
Logged this as a ticket!
Return to “Bug Reports”
