Curvature Precision Issue
rfrassek
Hi everybody,
I'm having an issue with the Curvature Texture node. It seems like it has precision issues. I modeled a 1:1 scale hypodermic needle model. It's very tiny, about 0.8mm in outer and 0.5mm in inner diameter. When I apply a Curvature Texture node and set the radius to 0.001 this is how it looks:
  • If I go ANY amount below 0.001 radius, the effect disappears entirely
  • Reducing Ray Epsilon does nothing
  • Dirt Texture seems not to be affected by this, but it does not give me the effect that I want so it's not an option as far as I can tell
  • Scaling the object up by 10x does help, but I would prefer to keep this to real life scale for obvious reasons
Is this just an Octane limitation or am I missing something?
Thank you!
which OctaneRender version are you using exactly?
And are you using Standalone or an integrated plugin?
ciao,
Beppe
