Cinema4D version 2025.1-Beta-2 Build 0102
ChrisHekman
Hi all,
With this build we are introducing partial RS Material support and the Octane 2025 Beta 2, along with fixes.
We are investigating an issue with the MacOS build, so we will be releasing that at a later date.
*Note: There is a known crash that can happen when loading older c4d files or octane materials from the asset browser
2025.1-Beta-2-0102 plugin revisions
RS Material support
  • Partial support for rendering RS materials
  • Partial support for converting RS materials to Octane materials
  • Requires Cinema4D R2024 or newer
Changes
  • Support for Nvidia RTX50xx-gen GPUs (Blackwell)
  • Chaos node is replaced with a new version using the new node system. This was done because Octane 2025 refactored the node
    Existing materials are not affected and still use the old node
  • Fixed issue where ORBX Loader was missing UI
  • Fixed naming and capitalization of objects, lights and tags
  • Fixed broken GUI for Max Samples and Depth sliders in OctaneRender Kernel Overwrite settings
  • Improved sliders on the Standard Volume node
  • Float Texture node can hold negative values
  • Removing AOV inputs now only removes last slot regardless if it is full or not
  • Unified and fixed compatibility modes’ GUI and conversion across shader nodes.
    Effected nodes:
    • Random walk
    • Absorption
    • Scattering
    • Standard volume medium
    • Volume medium
    • Box
    • Color to UVW
    • Cylindrical
    • Instance position
    • XYZ to UVW
    • MatCap
    • OSL projection
    • OSL delayed UV
    • Perspective
    • Sample pos. to UV
    • Spherical
    • Triplanar
    • Mesh UV projection
    • Image adjustment
    • OSL texture
    • Composite texture
    • Range
    • Vertex displacement
Downloads:
WINDOWS STUDIO+ 2025.1.Beta 2-0102 (R21-R2025)
Installer: https://render.otoy.com/customerdownloa ... 2Setup.exe
Zip: https://render.otoy.com/customerdownloa ... 2-0102.zip
Mac OSX Prime
Will add after issue has been resolved
Previous revisions
2024.1.2-[R2]-0101 plugin revisions
Installer and Versioning
  • We are introducing a new Windows installer for the plugin
  • Added plugin build number that indicates the specific plugin build regardless of R# or Octane version
  • Installer comes with Render Network Wizard
Octane Node Editor
  • Added a new underlying automatic node system for generating Octane nodes.
    New or refactored Octane nodes use this new node system.
    Existing nodes are unaffected. Existing Octane Materials are unaffected
  • Added missing Octane nodes. See list below
  • Refactored Value nodes. See list below
  • Refactored broken or incomplete nodes. See list below
  • Split the "Values" node category into Integer, Float and Boolean node categories to better match the Octane categories
  • Node Pins/Ports now have colors matching their category
  • Refactored right-click menu in the Octane Node Editor. Now shows all available Octane Nodes
  • Right-click menu in the Octane Node Editor now has search box
  • Pins/Ports now have descriptions when you hoover over them in the Octane Node Editor
GUI
  • Refactored the Objects menu in the Live Viewer and Octane Dialog
  • Refactored the Vectron submenu in the Live Viewer and Octane Dialog
  • Refactored the Materials menu in the Live Viewer and Octane Dialog
  • Restructured the Light Pass Mask UI
Octane Material Importing (LiveDB)
  • Added option to unpack an ORBX file into your C4D scene. Currently only materials and textures are extracted and converted from the ORBX
  • Improved Material importing from LiveDB and ORBX unpacking
  • Improved naming of extracted materials
  • Fixed asset download path for unpacking osl textures when importing material
  • Fixed bug where OLS input vector.x ze was negated when importing material
  • Fixed bug where Texture bordermode was ignored when importing material
Fixes
  • Polygon selection tag is now processed when there is no uvw tags
  • Fixed crash with particles during export when there is no Radius/Alignment set
  • Changed "Octane Renderer" to "OctaneRender" in Render Settings
  • Cloner's MODATA_COLOR is transformed from linear to srgb for Multi Shader textures
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 522) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..[/quote]
Node Additions and Deprecations
New Nodes
  • Time
  • Mandelbulb
  • Matrix effect
  • Sine wave fan
  • Volume cloud
  • Wave pattern
  • Woodgrain
  • Pixel flow
  • Int to float
  • Frame index
  • Output AOV parameter
Replaced Nodes
Materials using the older versions will still use older versions
  • Fractal flow noise
  • Fractal nois
  • Tripper
  • Rang
  • Float to grayscale
  • Floats to color
  • Float3 to color
Refactored Value Nodes
  • Float value
  • Float component picker
  • Float merger
  • Float if
  • Binary math operation
  • Unary math operation
  • Range
  • Time
  • Rotate
  • Int to float
  • Int value
  • Float to int
  • Frame index
  • Int if
  • Int merger
  • Int component picker
  • Bool value
  • Boolean logic operator
  • Float relational operator
  • Int relational operator
desire
May be something goes wrong with Compare feature at LiveViewer?
Can't make it work, shows just black frames at B-sector
upd: sorry, after the second start of a Cinema with 2025.1 plugin, Compare works
With sometimes deadly hangs over "Compare - Remove all" operation
WDH
not a bug but it's quite annoying. Every time Octane gets registered information, there is a python console error raised.
Traceback (most recent call last):
File "scriptmanager", line 3, in <module>
ModuleNotFoundError: No module named 'urllib2'
I checked the folder and seems octane is trying to write some scripts, but raised an import error, can we remove this?( this should be easy)
e-s
Awesome to see initial redshift materials/conversion support! :)
Just confirming based on the release notes, but the main feature that differentiates this 2025 build vs the latest 2024 build is the 5000 series support, right? The new 2025 features like decals are not implemented yet?
DinoMuhic
e-s wrote:Awesome to see initial redshift materials/conversion support! :)
Correct, only the new Chaos Texture node is in there.
The other 2025 features are coming in the next weeks, we are actively working on them right now but Decals and Rest Position need more work to make them usable, including new tags and objects that go along with it.
cjadams
Any ETA on the Mac build by chance?
cjadams wrote:Any ETA on the Mac build by chance?
we are working on it, stay tuned...
ciao,
Beppe
cjadams
ciao,
Beppe
AWESOME!
841131100
The X-axis position in the new version of HDR has shifted significantly compared to the previous version.
841131100 wrote:The X-axis position in the new version of HDR has shifted significantly compared to the previous version.
Yes, it is a known issue, it is rotating in the opposite direction in this version, so you need to invert the sign of Rotation X value while waiting for the fixed update.
ciao,
Beppe
