OctaneRender™ for Blender 2025.1.Beta.2 - 30.1 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to 2025.1.Beta2
  • Enhanced Octane DB, adding an import mode in the preferences panel
    • Append: Append Octane DB material nodes to the current material's node tree
    • Replace: Replace the current material with the imported Octane DB material
    • Create: Create a new material with the imported Octane DB material
  • Implemented Octane texture node tree editor
FIXES SINCE LAST RELEASE
  • Fixed Issue: Color Space Node associated with Images imported from DB
  • Fixed Issue: Textures do not load when importing a material from LiveDB
  • Fixed Issue: Render AOVs Preview Render Pass needs to be manually updated by the user right now.
  • Fixed Issue: Imager OCIO View and Look not having any effect on the render
  • Fixed Issue: OctaneDB Window Not Opening
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.1 Beta 2 here:
viewtopic.php?f=33&t=84549
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.1 (4.3.2)
Octane Server - Studio+ Edition - 30.1
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 30.1
