Cinema4D version 2024.1.2-R2 Build 0101
ChrisHekman
Hi all,
Some of you may be aware that Ahmet(aoktar) has reduced his involvement in the development of the C4D Plugin.
I have taken over as the lead developer. As part of the handover we took a step back to take a look at ways to improve our development and QA processes.
The aim of these changes is to reduce maintenance and increase development speed. Some of these changes will be very noticable (like the new installer), and many you will never notice.
Most of this work is now completed, and we have moved back to developing features.
Also, we will be releasing a 2025 Beta 2 version of this build soon. After that release we will be focussing on implementing the new 2025 features!
2024.1.2-[R2]-0101 plugin revisions
Installer and Versioning
  • We are introducing a new Windows installer for the plugin
  • Added plugin build number that indicates the specific plugin build regardless of R# or Octane version
  • Installer comes with Render Network Wizard
Octane Node Editor
  • Added a new underlying automatic node system for generating Octane nodes.
    New or refactored Octane nodes use this new node system.
    Existing nodes are unaffected. Existing Octane Materials are unaffected
  • Added missing Octane nodes. See list below
  • Refactored Value nodes. See list below
  • Refactored broken or incomplete nodes. See list below
  • Split the "Values" node category into Integer, Float and Boolean node categories to better match the Octane categories
  • Node Pins/Ports now have colors matching their category
  • Refactored right-click menu in the Octane Node Editor. Now shows all available Octane Nodes
  • Right-click menu in the Octane Node Editor now has search box
  • Pins/Ports now have descriptions when you hoover over them in the Octane Node Editor
GUI
  • Refactored the Objects menu in the Live Viewer and Octane Dialog
  • Refactored the Vectron submenu in the Live Viewer and Octane Dialog
  • Refactored the Materials menu in the Live Viewer and Octane Dialog
  • Restructured the Light Pass Mask UI
Octane Material Importing (LiveDB)
  • Added option to unpack an ORBX file into your C4D scene. Currently only materials and textures are extracted and converted from the ORBX
  • Improved Material importing from LiveDB and ORBX unpacking
  • Improved naming of extracted materials
  • Fixed asset download path for unpacking osl textures when importing material
  • Fixed bug where OLS input vector.x ze was negated when importing material
  • Fixed bug where Texture bordermode was ignored when importing material
Fixes
  • Polygon selection tag is now processed when there is no uvw tags
  • Fixed crash with particles during export when there is no Radius/Alignment set
  • Changed "Octane Renderer" to "OctaneRender" in Render Settings
  • Cloner's MODATA_COLOR is transformed from linear to srgb for Multi Shader textures
Downloads:
WINDOWS STUDIO+ 2024.1.2-[R2]-0101 (R21-R2025)
Installer: https://render.otoy.com/customerdownloa ... 1Setup.exe
Zip: https://render.otoy.com/customerdownloa ... 01_win.zip
Mac OSX Prime 2024.1.2-[R2]-0101 (R25-R26/R2023/R2024/R2025)
Zip: https://render.otoy.com/plugindownloads ... 01_OSX.zip
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 522) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..[/quote]
Node Additions and Deprecations
New Nodes
  • Time
  • Mandelbulb
  • Matrix effect
  • Sine wave fan
  • Volume cloud
  • Wave pattern
  • Woodgrain
  • Pixel flow
  • Int to float
  • Frame index
  • Output AOV parameter
Replaced Nodes
Materials using the older versions will still use older versions
  • Fractal flow noise
  • Fractal nois
  • Tripper
  • Rang
  • Float to grayscale
  • Floats to color
  • Float3 to color
Refactored Value Nodes
  • Float value
  • Float component picker
  • Float merger
  • Float if
  • Binary math operation
  • Unary math operation
  • Range
  • Time
  • Rotate
  • Int to float
  • Int value
  • Float to int
  • Frame index
  • Int if
  • Int merger
  • Int component picker
  • Bool value
  • Boolean logic operator
  • Float relational operator
  • Int relational operator
Good luck on this adventure!
thanulee
Thanks for everything Ahmet! I hope your next steps will be equally fullfilling.
And welcome Chris :)
WDH
Congratulations on achieving it, well done!
Perhaps taking this opportunity to revisit some pain points that are relatively easy to implement but have a significant impact on the experience:
unicode or utf-8 support, if we don't use English to name the material or shader, it will not show us the name.
Expose some commonly used command IDs, even if there is no public API, there are still some very useful functions such as aligning all nodes. If such IDs are exposed, users can write scripts to align and organize all materials at once.
Cheers~
DunHou
ChrisHekman
WDH wrote:Congratulations on achieving it, well done!
Cheers~
DunHou
Which script are you using?
Im taking a look into adding Traditional Chinese, Simplified Chinese and Korean(Hangul) because these are language settings that Octane has support for, or wants to support i think
It does seem to be possible. Ill see what i can do.
Anlv
This is exactly what everyone is hoping for!
I think what he said about the API interface is to automatically align all nodes with "Auto Arrange selected";
before, I tried to find the API for that menu to create a script to automatically align the nodes within all selected materials.
Cheers~
DunHou
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
ChrisHekman
Anlv wrote:This is exactly what everyone is hoping for!
Cheers~
DunHou
Ha, I meant writing script.
On the commands issue. These commands are theoretically already visible. The auto arrange command is in res/symbols_c4d.h. However i dont think it is possible to select all nodes via commands, so that wont help you.
Apart from C4D's nodes graph, our materials are based on Legacy system even for node graph. Everything are under data of materials and nothing is impossible to do via a script which you can do on C4D system.
What do you wish to do obtain at end?
WDH
aoktar wrote:Apart from C4D's nodes graph, our materials are based on Legacy system even for node graph. Everything are under data of materials and nothing is impossible to do via a script which you can do on C4D system.
We can do something like legacy material systems, but if we want to interact with nodes, it seems nothing we can do with Octane UI, like
the select state or the arranged functions are "internal".
I had a python library called Renderer, it supports all popular renderers in c4d, but I didn't find some attrs we can aceess in Octanes custom UA node system.
KeeWe
Thanks for the update on the future development. :)
Switching to an installer is nice, but could we take it a step further and do an in app update feature just like insydium for example? A prime version would even let you choose the build...
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
