OctaneRender™ for Blender 2024.1.2 - 29.19 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Update version number to 29.19
  • Added "Keep up-vector vertical" for lens camera
  • Add an option to exclude AOVs from being saved to EXR
  • New layout for the Octane info in the preview
  • Implemented OCIO View List missing in the Compositor Imager node
FIXES SINCE LAST RELEASE
  • Perspective Correction option not working
  • Object Layer node
  • LocalDB Materials not loading fine in Octane for Blender
  • Color Correction node Brightness issue
  • Using Custom 20 AOV makes the server crash on render
  • Global Texture 20 AOV makes the server crash on render
  • Textures do not load when importing a material from LiveDB
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2024.1.2 here:
viewtopic.php?f=24&t=84359
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.19 (4.3.2)
Octane Server - Studio+ Edition - 29.19
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 29.19
