versions 15.11 and 15.12 VERY Octane Viewport - crashing
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
MartinBoom
since versions 15.11 and 15.12 i'm having several and constant crashes when rendering into octane viewport (open octane viewport)
running the Nvidia studio drivers 572.16 (latest when posted) and previous versions (of drivers and octane 15.11) also had the same issue.
3ds max 2018.
the scenes are not that big (below 2 millon polys) forestpack but minimal.
i not able to isolate what could causing it but, as the copying any texture black body with ies was crashing. i think it has to do to the stability of the build itself.
unusual and a workflow killer.
regards
martin
paride4331
Hi Martinboom,
It took me a little while to find and install 3ds Max 2018 and downgrade it in order to open a file for testing. That being said, I haven't encountered any of the issues you've mentioned, everything seems to be working fine. For reference, I'm using Nvidia drivers 566.14 (Studio driver), in case that helps.
Regards
Paride
Return to “Bug Reports”
