OctaneRender™ for Blender 2024.1.2 - 29.18 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated version number to 29.18
  • Upgraded to Blender 4.3.2
  • Supported multi-meshes in a single Geo nodes
  • Enhanced GUI to display the Octane Blender version and Octane SDK version on viewport and status bar
  • Supported Custom Output File Names for AOVs
FIXES SINCE LAST RELEASE
  • Fixed Version Number Mismatch
  • Fixed Analytic light is called Analytical light in Octane for Blender
  • Fixed 3D View Clipping issue
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2024.1.2 here:
viewtopic.php?f=24&t=84359
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.18 (4.3.2)
Octane Server - Studio+ Edition - 29.18
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
