OctaneRender™ for Blender 2024.1.2 - 29.17 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.3.1
  • Updated to Octane 2024.1.2
  • Supported Support Blender Point Cloud in Addon version
FIXES SINCE LAST RELEASE
  • Fixed Grease Pencil's UI options missing when Octane addon is enable
  • Fixed Custom frame number when exporting ORBX
  • Fixed Rendering USD particles in Octane for Blender
  • Minor Bug fixes.
HOTFIXES 29.17.1 (27/12)
  • Updated version number to 29.17.1
  • Fixed ORBX Export issue
You can read about new features of OctaneRender™ 2024.1.2 here:
viewtopic.php?f=24&t=84359
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.17.1 (4.3.1)
Octane Server - Studio+ Edition - 29.17
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Blender Octane Edition - 29.17 (4.3.1)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
