OctaneRender™ for Blender 2024.1 - 29.16 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Blender 4.2.3
  • Upgrade the export system
  • Implemented the OCIO Look node
  • Completed attributes for Tiled images
  • Supported specifying server address & ports in Python API
FIXES SINCE LAST RELEASE
  • Fix several export crashes
  • Fixed the Octane DB problem of Prime version
  • Fixed the missing object data panel of lights
  • Fixed auto smooth problem
  • Fixed traceback when converting property with invalid values
  • Fixed crash when using empty legacy image nodes
  • Fixed crash when trying to resolve legacy disabled sockets
  • Fixed empty property in the legacy Dirt Texture
  • Minor Bug fixes
HOTFIXES 29.16.1 (26/11)
  • Upgraded to Blender 4.2.4
  • Fixed a crash when using Geo node with empty node tree
You can read about new features of OctaneRender™ 2024.1 here:
viewtopic.php?f=24&t=83998
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.16.1 (4.2.3)
Octane Server - Studio+ Edition - 29.16
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
