General .orbx export questions
Houdini Integrated Plugin
HSchoenberger
Hi
I am testing the .orbx export and I have some questions.
There are in general 2 modes to export archives from Houdini and render them with a standalone renderer:
1) 1 archive file per frame
2) A single archive file that contains all frames.
Now my test results:
If I specify a frame number in the "Base file name" like ${HIPNAME}_$F4, then Octane still exports one file with all frames only.
I created a script with a loop to set the ROPs Frame Range Start/End for each frame.
And call the export command for each frame this way.
It works so far.
But it would still be nice if Octane supports this out of the box.
Only issue I found: It will not render motion blur this way.
The only workaround is to export the next frame into the file as well.
If I export a single file with all frames (as this is the way you intended the orbx export should be used).
But I cannot use that file to render all frames on our farm.
As the octane-cli.exe executable has no flag to specify which framw should be rendered.
Is the --help documentation missing some flags or how can I solve this?
ricky_otoy
Sorry for the delayed reply!
Ah ok :) I had to re-read your message, you saying that you are exporting per frame via your script right?
Yeah we don't support splitting the ORBX yet but will be looking into it.
HSchoenberger
ricky_otoy wrote: Tue Nov 19, 2024 5:01 pm Yeah we don't support splitting the ORBX yet but will be looking into it.
Hi
Sorry for my reeeaaaly delayed reply (Did not got an email as I forgot to ticket that option.)
I stated 2 possible options to export archive files:
And you answered, it is not possible to have "1)" with Octane.
It is possible export a single file with all frames only "2)".
But what about the issue I stated in 2)?
Example:
I have an scene with frames 1-100.
I export an .orbx with all the frames.
How can I render frame 50 of the .orbx file with octane-cli.exe?
dom_otoy
HSchoenberger wrote: Wed Oct 08, 2025 2:06 pm
Hi
Example:
Heyo!
I will check with the standalone devs as this is less Houdini plugin related!
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
Return to “Houdini”
