Disable single GPU during network render
mikefrisk
Is it possible to disable your local GPU during network render if you only have 1 card? If you have 2 or more GPUs there are options on the render preview UI to enable/disable individual GPUs, which is nice because i'll start the render, let it load, then disable all my local GPUs essentially leaving only the network nodes to do the rendering this leaves my local card free for other tasks. However I recently swapped out my two local cards for one more powerful card and I no longer can disable my local GPU.
mikefrisk
No solution to this? No way to "send to network" for rendering? I would really like to render using only network GPUs...
pryzm
IIRC, they were working on a "headless" render (you don't have to use the main machine to render), but I haven't seen any news of it yet.
Return to “Lightwave 3D”
