Working with tiny chracters?
coilbook
Hello,
We are planning to animate tiny characters like bugs, etc inside the house (similar to "Honey i shrunk the kids").
Do you recommend keep the scale true or scale up the house and the environment and make insects around 10-20 centiliters in length?
Thank you
coilbook
skientia wrote:Briefly, it depends on several factors, provided it's reasonably small:
- will the scale change or remain as set? (e.g. from "tiny" to human size)
- Is there much SSS based shading?
- Is the DoF rendered in Octane or in post?
and so forth.
It's always possible to test a rudimentary scene and see how viable the workflow is with all the factors at play.
The Kernel's Ray Epsilon is suited for situations like this.
Thank you!
Return to “Autodesk 3Ds Max”
