Dear OTOY Support,
I'm running HoudiniFX 20.5.370 with the matching Octane build Version 2024.1.0.1 on Windows 10.
My workstation is a AMD TR3970X, 128GB RAM, 2x3090.
I'm having trouble exporting a proper Post Pass when the Alpha Channel is enabled.
I have particles with an emissive material in the scene. Unfortunately, their post effects don't show up, unless they're "in front" of geometry.
In the C4D Version of Octane this has never been an issue, so I wanted to see, if this behavior is expected. Maybe I should add, that I have
around 10yrs experience, working in Octane for C4D, but have just now made the transition to Octane for Houdini. Is there something I'm missing?
Thank you for your help!
Gregor
Post Pass with Alpha Channel
C. RAM Capacity (i.e. 6 GB)
- Gregor.Zimmermann
Yes, EXR. I did try and use PNG, but it yielded the same results.
- Gregor.Zimmermann
Hey skientia,
appreciate you taking the time!
So, essentially I used all the same settings, I'd use in Cinema4D.
I think, I'll have to do some more testing here.
Since you pointed out that everything works as expected in Standalone, I'd say this might be a plugin issue.
I'll read through the page you posted, too.
- ricky_otoy
Hi Gregor, can you post an image or provide a scene file?
If you export to Standalone from Houdini, and save there do you get different results?
