Alpha doesn't work properly in fog volumes?
Hurricane046
Hello, im facing a problem with simple 2D texture with alpha inside Fog Volume. The full geometry gets revealed by the fog which is bad when using alpha textures. I set up a simple test demostrating this. Any idea how to fix this issue?
Thanks!
EDIT 1: We're currently testing this workaround, I'll let you know if it helped.
EDIT 2: Workaround doesn't work. You have to stick the camera into the cube with volume to see it which is something we cannot do in our case. So yeah I think the alphas in fog volumes are still broken and need to be fixed.
