OctaneRender™ for Blender 2024.1 - 29.15 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated Octane Default Startup scene
  • Supported multiple node groups in the same shader node tree
  • Updated the subtype of some texture layer nodes, changing from float to percentage
FIXES SINCE LAST RELEASE
  • Fixed viewport render issue when toggling "Auto-Smooth"
  • Fixed misalignment bug when using "Always use camera resolution"
  • Fixed the missing viewport overlay GUI issue
  • Fixed issues of OSL Camera node
  • Fixed issues when loading some legacy scenes
  • Fixed the problem of wrong osl camera transformation
  • Fixed the out-of-date OctaneDB GUI issue when localDB path is changed
  • Fixed the light direction issue of directional light
  • Fixed issues of domain transform node
  • Fixed a redundant update caused by ramp and OSL nodes
  • Fixed a reiterated update issue when rotating light direction
  • Fixed traceback when converting legacy data
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2024.1 here:
viewtopic.php?f=24&t=83998
1. OctaneRender™ Server
Windows
Blender Octane Edition - 29.15 (4.2.1)
Octane Server - Studio+ Edition - 29.15
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
